Old 06-28-2017, 03:01 PM   #1
reeper
reeper's Avatar
Drives: 2010 HD D/A, 2015 Z06, 2016 2SS
Black Crystal Seal after clay bar?
Hi All,
I'm just curious if it would be appropriate to re-apply black crystal seal after a hand wash and clay bar? I previously used it in May. The car is not a daily and lives a lot in the garage.
On a side note how do you know when to re-apply black crystal sea?
Thank you
2016 Hyper Blue A8 2SS
GM Bodykit: Black
MRR 017 wheels: Black
OEM Blackout tail-lamps
OEM SEMA Grille
35% window tint
Black glow-tie
BMR Suspension (Pretty much everything)
ACS rear-deck spoiler
Rotofab CAI
Lolly-pop red rotors by Madison Powder Coating
reeper is offline   Reply With Quote
Old 06-28-2017, 03:08 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
You should lay on a layer of polish before you put on the Crystal seal, after the Clay. Blackfire "total polish and seal" is a good one that goes with Crystal seal.
You should apply Crystal seal anywhere between three and six months, whenever you feel like it.
Old 06-28-2017, 03:10 PM   #3
reeper
reeper's Avatar
Thank you Glen
GM Bodykit: Black
OEM SEMA Grille
35% window tint
Black glow-tie
Rotofab CAI
Old 06-28-2017, 03:17 PM   #4
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
The total polish and seal is good stuff. The blackfire seal is amazing. You really should look into the clay bar glove. it is amazing. You can clay your car in the same amount of time it takes to wash it and its safe on every part of the car. Even the glass.
Get the nanoskin glove
SSTony is offline   Reply With Quote
Old 06-28-2017, 03:20 PM   #5
reeper
reeper's Avatar
What pad would you recommend on my polisher?
GM Bodykit: Black
OEM SEMA Grille
35% window tint
Black glow-tie
Rotofab CAI
Old 06-28-2017, 03:21 PM   #6
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Any medium foam pad...speed also medium
Old 06-28-2017, 04:03 PM   #7
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Before you apply the sealant, you want to wipe the paint down with either IPA (Isopropyl Alcohol) diluted with distilled water 10-15%, or Carpro Eraser.
What this will do is remove any residue left from your clay lube, oils, or soap residue on the surface, giving your sealant the best possible surface to bond to.
This step is critical to get maximum longevity out of your sealant.
Think of sticking 2 pieces of tape to something. One area is completely clean and free of any residue. The other is clean, but has some residue on it. Which piece will bond better? Same concept when applying protection.
Prepping it properly before applying you should get at least 4 months out of it on a garage queen.
You'll know when it's gone because the surface will no longer bead or sheet water.
Since your car is a garage queen, I'd highly recommend Ultima Waterless Wash Plush concentrate and a good California duster for cleaning the dust off, which with a garage queen, this is mostly what you'll get on the car.
Many people say the CD is a bad product, that it will scratch paint. It will if used improperly. Here's how to use it right.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 06-28-2017, 04:50 PM   #8
FlowForm_Wheels
FlowForm_Wheels's Avatar
Drives: Turbo 4, SC V8 and Twin Turbo V8
Originally Posted by reeper View Post
Hi All,
Thank you
Doesn't matter what clay bar you used, once you clay a car, you're still putting some scratches down while picking the debris up. Seal it now and you're sealing in the small scratches, so it's always recommended to polish those out, then seal.
FlowForm_Wheels is offline   Reply With Quote
Old 06-28-2017, 04:58 PM   #9
reeper
reeper's Avatar
That makes perfect sense. Thank you.
GM Bodykit: Black
OEM SEMA Grille
35% window tint
Black glow-tie
Rotofab CAI
Old 06-28-2017, 05:50 PM   #10
Burly
Burly's Avatar
Does the CarPro Ech2o compare to Optimum Waterless wash recommended in the video in terms of lubrication properties(lubricocity)?
Burly is offline   Reply With Quote
Old 06-28-2017, 05:53 PM   #11
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
I've never seen one that was substantially better than the others, they all work really well. I've used about five, the echo2 is different in that it's got silica for a bit more protection. They all exhibit lubricity.
Old 06-28-2017, 08:25 PM   #12
Joe M 2012 2SS
Drives: 2012 2SS
I'll second this.
The ultima or optimum is a better choice if you have a regular polymer sealant, the ECH20 is designed for coatings or silica based products like Reload, Hydro2, Hydrofoam, etc.
Ultima also has a newer version that has Acrylic in it. I haven't used it, but it's supposed to provide a little more protection then the original.
The benefit to Ultima, Optimum, and ECH20 is they are concentrates, so your cost is much lower versus buying pre mixed products. Your paying much more that way.
I get the Ultima on sale at AG for about $15 w/ free shipping on one of their 25% off free shipping sales. Distilled water is 88c per gallon at Wal-Mart. So for around $19, I get 5.5 gallons of solution.
The Optimum is also a good value to mix waterless wash/detail spray/clay lube.
I get my Carpro stuff from Corey only, because he has helped me when I've ran across difficult paint to polish several times.
He has good sales on Black Friday/Cyber Monday, and occasionally throughout the year. Of course you can get 15% off any time using code 15off at Carpro USA.
For the OP, if you clayed the car in May and it's a garage queen, it's highly unlikely that it will need claying again in 4-6 months.
An easy way to check is do the baggie test after washing.
When it's time to re-apply, all you'll need to do is a strip wash, IPA or Eraser wipe down, and apply your sealant.
Old 06-28-2017, 09:18 PM   #13
reeper
reeper's Avatar
I have a bottle of Chemical Guys V36 and V38. Would either one of those work?
I'm thinking just the V38 as I only have 1500 miles on the car and no swirl marks.
GM Bodykit: Black
OEM SEMA Grille
35% window tint
Black glow-tie
Rotofab CAI
Old 06-28-2017, 11:09 PM   #14
SSport16
SSport16's Avatar
Agree on the Ech20...on a different level if you are using Silica based products, awesome stuff!
