Make America Fast Again
Drives: 2016 HBM 1SS - M6 Join Date: Sep 2016
Torque Management/Throttle Response
Is it possible to tune out the torque management, and completely remove the insane lag that's present in both tour and sport mode?
In an M6, you can literally floor the car and feel it wait half a second before actually pulling in both touring and sport mode. I was also curious if it's possible to completely turn off/tune out the torque management. If I'm 100% throttle, I want the throttle blade 100% open. |
![]() ![]() ![]() ![]() ![]() Drives: 18 Silverado 1500 Join Date: Dec 2015
Yes, it changes the car into a different beast altogether. Also, look into porting the intake and throttle body while you are at it.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Will require custom programming.
[COTW 1/6/14]
Drives: 2017 1LE Join Date: Mar 2012
so from my understanding.. even with all nannies off (tc button for 10 secs) the TQM will still be there
![]() ![]() ![]() Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
The whole system is based off of torque management. You cannot remove it all together. The more dialed in you can get the torque management the less you think its there.
![]() Drives: Camaro SS, G35 6MT, Cherokee Sport Join Date: Jun 2016
Yes unfortunately the way the architecture the PCM is designed makes it EXTREMELY difficult to skirt this. A programmer can work to change the pedal mapping but it will be difficult to eliminate all interventions from the torque management system without getting rid of the factory engine management altogether.
#7 |
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
I hear others speak of this lag...I have absolutely no Lag. In fact mine damn near feels like a cable throttle.
#8 |
![]() Drives: 2017 Camaro SS & 2018 ZL1 1LE Join Date: Mar 2017
I've got no lag in mine. Maybe I just don't notice it? I know my throttle response increased when I installed my gm cold air intake
#9 |
avacamaro
Drives: 2016 silver SS Join Date: Apr 2012
#10 |
[COTW 1/6/14]
hmm well manual wise.. I notice it when I was on the track. best run with street tires was 12.6 but no matter what RPM I launch it at there is also a nice little bog on launch getting the car rolling
