![]() Drives: 2016 red hot 2ss Join Date: Jan 2017
camshaft help!!!!
I want to change camshaft and supporting items ...i was looking at the TSP VVT2 camshaft but I don't know if it will be big enough what I'm wanting most is sound 1st an performance 2.my car is bone stock at the moment
Drives: Duramax Join Date: May 2017
You don't have to change the Camshaft if you want to improve exhaust noise. There are several Hi-Performance aftermarket exhaust systems that have been posted about in that sub-forum and the guys love the sound.
If you change the Camshaft you're going to have to change the Tune($$) and possibly adjustments to the fuel/induction system, (more $$) to keep up with the Camshaft profile and it's going void your GM warranty. Just my 2 cents, Good Luck and have fun. |
SABIO
I suggest calling them
The guys grinding up these camshaft can easily answer all your questions.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Audi TT RS Join Date: Jan 2014
It's worth noting that if you have an automatic, anything larger than their SV camshaft will require a different torque converter to run. With that in mind, that could prove tricky as very few people have swapped theirs out and even fewer tuners have attempted to get aftermarket torque converters on these cars to play well. If you have a manual, I think all you'll need is a bit more throttle to modulate yourself off the line better.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
![]() Drives: 2016 Camaro SS Join Date: Dec 2016
I used an LTVV1 in a 2016 Camaro and a LTVVTSV in a C7 Corvette and both act and work great with the stock torque converter. If you go with the VVT2 it would not be happy with the stock torque converter.
![]() Drives: 2016 2ss Join Date: Jan 2017
Ive got a bRand new vvt2 cam id sell for 400 shipped. I bought it with plans to stay NA but now planning to do a custom cam more suited for the procharger ill add later.
#7 | |
![]() Drives: 2017 ZL1 A10 Join Date: Aug 2016
Thanks |
#8 |
![]() Drives: 2016 Chevy Camaro Join Date: Jun 2016
My opinion would be :
1) Drivability 2) Performance 3) Sound (idle quality) I think and hope most would agree with an aftermarket cam in this order. Next would be MY preference. GPI SS1 BTR Stage 1 N/A Both will net about the same HP and great overall performance, while still being mild mannered enough to not allow any "push" through the stock torque converter. But there's another one I'm adding to the list. Lingenfelter GT32. Excellent specs and should net nearly the same performance as the two aforementioned. This one just might go in mine next month. Also just as important as the cam itself is its supporting cast. A really nice valve job right along with a BTR .660 spring set and CTSV-R lifters will make a great cam an awesome cam... Hopefully I was helpful... |
#9 |
![]() Drives: Chevrolet Camaro SS Join Date: Mar 2015
If sound is all you want look into a "ghost cam" essentially a tune that gives you the lump you're looking for but with the stock cam.
#10 | |
![]() ![]() ![]() Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
Am also contemplating a TSP VVT stage 2 vs BTR NA/SC cam, however, I am not sure I want to go with a lash cap on what will most likely remain a NA build. |
#11 |
DFW1LE, with stock cam lobe you dont need a lash cap. The stage 2 tsp vvt2 i have is just that. I originally thought id stay na, now im leaning towards supercharging down the road. Planning on going with a custom grind for decent power na now, but will also work great later with the charger.
#12 | |
#13 | |
#14 | |
