Old 06-22-2017, 01:34 PM   #1
citizennick
Drives: 2016 2SS
Running my track setup without TPMS?
About to have my new wheels and tires mounted this weekend and was wondering if I could forgo putting my TPMS sensors in without any issues. Would rather not have to take it somewhere all the time to have the TPMS sensors from each set re-paired to the car.
2016 2SS M6 Black/Adrenaline Red
589rwhp 572rwtq 429 LT1
citizennick is offline   Reply With Quote
Old 06-26-2017, 01:45 PM   #2
slick3
Drives: Garnet Red - 20 ZLE
Nick,
Have you tried putting them on the car, Removing ALL THE AIR. Key on, Key off, Fill them all back up and key on? Obviously this is if you decide to get TPMS sensors....
Used to work on my Mustang. Not sure about the camaros. I got new TPMS sensors for my track wheels but didnt get the learn tool yet. I will try it out when I get them and let you know.
slick3 is offline   Reply With Quote
Old 06-26-2017, 01:53 PM   #3
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
I don't run TPMS sensors in my track wheels and there are no issues except the little orange icon on the dash.
Eric SS is offline   Reply With Quote
Old 06-26-2017, 02:22 PM   #4
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i used to have to switch back and forth from my hre wheels to my stock wheels and i would have the light on for a day or so and then it would go back when i put the wheels back with the sensors in
Old 06-26-2017, 02:52 PM   #5
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
I would rather check and adjust my tires throughout the day myself than trust the TPMS.
I don't have them in my FS01s. No issues.
Old 06-26-2017, 06:03 PM   #6
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Non-1LE's don't have PTM modes, right? A TPMS issue will prevent cars equipped with PTM from going into PTM mode. If that isnt an issue for you, then I don't see a reason you "need" the sensors. With that said I have a set in my track wheels and I bought a $40 remote so I could repair the car when I switch wheels.
seanblurr is offline   Reply With Quote
Old 06-26-2017, 06:51 PM   #7
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Bypass the entire TPMS system:
https://www.clublexus.com/forums/is-...pipe-bomb.html
Old 06-30-2017, 01:20 PM   #8
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Would a TPMS issue prevent you from simply turning everything completely off and setting individual items such as steering even if your car did have PTM modes?
Norm
Old 06-30-2017, 03:08 PM   #9
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
You don't need them but I want to note that I am impressed with the seeming accuracy of these TPMS sensors.
As I was airing up my tires this weekend, I watched from the dash as the PSI went up in each tire matching what the gauge on my tire compressor was showing. Pretty cool.
The one advantage I can see is that if you trust the TPMS readout on the dash, you no longer have to do the hand gauge measurements between runs. Which adds convenience and saves time. You can also see what they are at during your hot laps by glancing at the readout rather than wait until you get into the pits...so you know the PSI your tires run at when you are at 10/10ths not just after you've let them cool a bit as you coast into the pits.
Did that make sense?
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 06-30-2017, 03:49 PM   #10
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Norm
PTM uses the tpms to tell what the tire temps are to assume grip levels. I suppose there are default modes if tpms is non functional. But steering/exhaust modes should not be affected
thescreensavers is offline   Reply With Quote
Old 07-04-2017, 02:00 AM   #11
OminouSS
OminouSS's Avatar
Drives: Red Hot track candy
my sensors are so off. I have 4 sets of wheels and took sensors out of all but my stockers.
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
OminouSS is offline   Reply With Quote
Old 07-04-2017, 07:56 AM   #12
Norm Peterson
The only way I can see that working is if either TPMS or Stabilitrak infers a temperature rise from the pressure increase. Which sounds like if you don't set the tires to door sticker pressures, TPMS would basically be telling lies to Stabilitrak. Does anybody ever set tires used in autocross or HPDE to those? I kind of doubt that everybody sets their cold 'street' pressures to sticker numbers.
If you're running R-comps or only something like RE71R's, ST might leave more usable grip "on the table" than necessary because it doesn't know how much grip is really available.
Sound reasonable?
Norm
Old 07-05-2017, 02:03 AM   #13
MoreSpeed
MoreSpeed's Avatar
No issues with non TPMS wheels other than the indicator light as mentioned above.
However I bought a $38 tool on Amazon that will make my car read the new TPMS setup for the new wheels. They don't automatically pick up the new wheels and new sensors. For that matter, they will not even pick up the same factory sensors if you rotate non-directional tires side to side. The tool resets the TPMS so it can read the sensors for that particular wheel.
I find tire pressure readings are helpful in autox and I like others here find the readings pretty accurate.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG
etc..
MoreSpeed is offline   Reply With Quote
