Old 06-15-2017, 03:08 PM   #1
Marty McFlew
Drives: 17 SuperSport Camaro 6 on the Flo'
How do you tighten up the display?
I understand there are screws that will tighten up the 8in. display. How do I access them?
Marty McFlew is offline   Reply With Quote
Old 06-15-2017, 03:20 PM   #2
E-Ray
Drives: 2016 Camaro 2SS, Nightfall Grey
Starts @150
E-Ray is offline   Reply With Quote
Old 06-16-2017, 01:10 AM   #3
Marty McFlew
Originally Posted by E-Ray View Post
Starts @150
Old 06-16-2017, 08:02 AM   #4
Dethsupp0rt
Drives: None
Starts @150
I like those pads/trim panels. Going to have to look into those.
Dethsupp0rt is offline   Reply With Quote
Old 06-16-2017, 07:23 PM   #5
thinkingcamaro
Drives: 2017 Summit White Camaro 2SS
Originally Posted by Marty McFlew View Post
Interesting. I wonder if those screws are the cause of the rattle I hear coming from around the display...
thinkingcamaro is offline   Reply With Quote
Old 06-16-2017, 11:41 PM   #6
high_climber
Drives: 2017 1LE Hyper Blue Metallic
I just had this fixed by the dealer by adding insulation to prevent the top of the screen play from rattling. Tightening the screws in my case didn't help
high_climber is offline   Reply With Quote
Old 06-17-2017, 12:25 AM   #7
slick3
Drives: Garnet Red - 20 ZLE
The physical wheel and button for volume on mine rattles. Super annoying and no idea how to fix it except maybe get a brand new button panel all together.
slick3 is offline   Reply With Quote
Old 06-17-2017, 01:05 AM   #8
tone228
Drives: 2SS
Tightened mine a while ago. Did nothing to stop the screen from rattling. Now that's it's warm outside the car is dead quiet. This past winter my car had rattles everywhere. Drove me nuts.
tone228 is offline   Reply With Quote
Old 06-17-2017, 08:50 AM   #9
E-Ray
Thought it may help by adding a thin rubber gasket between the screen and backing.
Old 06-17-2017, 10:24 AM   #10
rap47
Drives: 2017 Camaro SS 50th
The only rattle on mine was the screen. Took the two bolts out as shown in the video above. Added a 4" long strip of foam weather stripping (sticky on one side) to the upper back side of the screen and reinstalled. Zero rattles now!!
rap47 is offline   Reply With Quote
Old 06-17-2017, 10:38 AM   #11
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
I have actually found that the center button on my setup has been a cause of rattling. Still trying to figure out how to deal with it.
Sledgehammer70 is offline   Reply With Quote
