Old 06-14-2017, 10:10 PM   #1
trukgirl
trukgirl's Avatar
Drives: 2016 1LT RS Conv, 2015 Silverado CC
Send a message via Yahoo to trukgirl
Question Heat coming up on drivers side with top down
Has anyone else noticed a ton of heat coming from the floor/pedal area on their drivers side with the top down???
I have not had anyone notice it on the passenger side even when asked. Seems like unless I am running the AC on the floor, no matter the temp setting, if the environmental controls are off, on vent, or on the windshield, I have a lot of heat on my legs. Even on nice evenings where its a little cool I am still hot!!!! You can put your hands on both sides and only feel it coming up from the drivers side. My husband drove my car to the grocery store this evening and he finally noticed it too. It mostly happens with the top down but also happens with windows open.
Is anyone else experiencing this??
Car is a 1LT RS 2.0T
2016 1LT RS Convertible White/Black - DD!
Instagram - trukgirl
Past Camaros:
2012 1LT Silver Ice
1989 RS 305v8 Medium Maui Metallic Blue, T tops
trukgirl is offline   Reply With Quote
Old 06-15-2017, 08:32 AM   #2
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
I have not noticed this. The temps on the floor vents follow whatever the controls are set at for me. I had the heat on a little bit with a 55F degree ride into work this morning.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 06-15-2017, 01:16 PM   #3
VABarn
Drives: 2016 Hyper Blue 2SS Vert
Sorry to hear this is happening to you. I haven't had any issues. Not sure if it matters, but I have a 2ss.
VABarn is offline   Reply With Quote
Old 06-15-2017, 02:11 PM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I have a 2SS convertible and haven't noticed this on my car. Maybe put a small thermometer on both sides to measure the temperature difference and then talk to a service advisor at the dealer.
Old 06-15-2017, 03:19 PM   #5
Camaro6Dave
LATENIGHTWDAVE
Camaro6Dave's Avatar
Drives: 2016 Camaro Convertible 2SS
I have a 2SS convertible and noticed the same issue. Did not have the temperature controls on, but noticed the temperature dials were set to 74. I turned down the temperature to the high 60's, it seemed to take the heat away. I am going to continue to monitor to see if there is heat on drivers side.
Camaro6Dave is offline   Reply With Quote
Old 06-15-2017, 03:37 PM   #6
MANNAXMAN
MANNAXMAN's Avatar
2SS vert here also. I have no issues like what you're experiencing. It's very interesting that it only happens when the top is down or with the windows open.
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 06-17-2017, 02:25 AM   #7
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
Have not noticed but I have only driven mine a few times since delivery in April I will have to check again when I drive it next month (I hope).
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 06-17-2017, 01:56 PM   #8
Donrican
Donrican's Avatar
Drives: 2018 Camaro ZL1 Convertible
I noted with my last car that I would get hot air when the AC was turned off. I wonder if the vent continues to pull hot air in with the AC off. Turning the AC down even with the AC off also helped.
2018 Camaro ZL1
Donrican is offline   Reply With Quote
Old 06-17-2017, 02:01 PM   #9
dowright82
Drives: 2017 Alpine White 6M SS
It's not just with top down - I have a hardtop coupe that exhibits this exact issue. Constantly when it's cool outside
dowright82 is offline   Reply With Quote
Old 06-17-2017, 03:53 PM   #10
jreagle56
jreagle56's Avatar
Drives: 2022 2SS A10 NPP MRC Red Hot
same happens in my car; its a coupe.
When the temp control in the car is set higher than the ambient outside air temp, heat moves thru the ducts into the cabin. turn down the temp control in the car below the outside air temp and it seems like the damper closes off the heat.
It appears the damper that flaps between the heat core and ac coil is always moving back and forth depending on outside air temp and cabin temp control setting. It doesnt matter if the system is on or off. Just a guess, but that is what seems to be happening. i always have fresh air open, not sure what happens when recirc is activated......
Just my 2 cents FWIW.
[SIGPIC][/SIGPIC]
jreagle56 is offline   Reply With Quote
Old 06-20-2017, 11:38 PM   #11
trukgirl
trukgirl's Avatar
It doesn't seem to matter what temp I have it set at. I even put it on LOW and it still won't stop unless the system is on and have AC on.
The temps have been in the 80s-90s here in day, so having it hot on my side makes me want to keep the top up and ac on... even at night when its nice and cool with the sun down! :(
ETA I don't think it matters if its a coupe or not.... I had a mazda miata that never had this problem, and my other two camaros didn't do it either, even the one with the t tops.
I have also tried it on recirc and off, doesn't seem to matter if the AC is off.
Thank you for all the responses
Past Camaros:
2012 1LT Silver Ice
Old 07-18-2017, 09:52 AM   #12
trukgirl
trukgirl's Avatar
I rode in the passenger seat a few times to go get ice cream (top up and down) and its definitely different, no hot air.
I have noticed it more at highway speed ... just took first 4hr road trip in it last week and it was happening some even with the top and windows up. There has got to be some sort of insulation missing in my car, or something of that type... thats what it seems like. Its even more noticeable since the temps have gone up here, high 90's and into 100s.
I think I may be taking it in for the first oil change soon so I am going to have them look at this while its in. Super annoying!!!!
Past Camaros:
2012 1LT Silver Ice
Old 07-23-2017, 12:54 PM   #13
somedude
somedude's Avatar
Drives: 2017 Camaro 1LT Convertible Auto V6
trukgirl, I am having the exact same issues on my 2017 RS I have tried different settings to no avail and it is more noticeable on the freeway with the top down.
somedude is offline   Reply With Quote
Old 07-23-2017, 08:41 PM   #14
Bigdog9586
Drives: 2016 Z06 coupe
My 14 Vette had a heat problem along with many others. GM reprogrammed the air software and it helped.
Bigdog9586 is offline   Reply With Quote
