Old 06-13-2017, 11:37 PM   #1
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
Katech ported throttle body throwing codes
UPDATE
I got my replacement Throttle body and it works perfect. Car sounds like it is sucking in more air. No butt dyno so I won't say any type of gains. I do notice a little better throttle response.
So i got my Katech ported throttle body today and i install it. I turn the car on and it runs like shit. Throws 2 engine codes P0123 and P0222. It also says in car that performance reduced. I take it off and put the original back on. Runs great but now i got 2 codes that wont clear.
What is going on? I didnt disconnect the battery when i installed it.
SSTony is offline   Reply With Quote
Old 06-14-2017, 12:06 AM   #2
slick3
Drives: Garnet Red - 20 ZLE
The TB motor is TOAST. Been there, done that. You can try something if you want. It did not work for me but it was something I found with some digging awhile back that worked for some guys with the C7 and C6 vettes
Unplug throttle body
IGNITION on (do not turn the car on)
Sit 2 Minutes
IGNITION OFF
Sit 2 Minutes
Disconnect battery
Plug back in TB
Reconnect battery
IGNITION ON 2 Minutes
IGNITION OFF 2 Minutes
Start the car and then just let it idle there for 5 minutes. Tunn the AC on, let it idle for another 5 minutes.
Do you have HPT? If so it can be very usefull in reading throttle position. The codes your getting are basically saying, hey the blade is open this much but it should be open XX amount according to the computer and the differential is too high.
slick3 is offline   Reply With Quote
Old 06-14-2017, 12:19 AM   #3
M12LRV
Drives: .
I heard Katech had a defective batch in another thread. Contact them
http://www.camaro6.com/forums/showth...ghlight=katech
2016 1SS Hyper Blue Metallic, A8, MRC, NPP
M12LRV is offline   Reply With Quote
Old 06-14-2017, 06:20 AM   #4
Fraxum
Fraxum's Avatar
OP This can happen, return the TB. It happened to me. I had to get a hold of another TB and switch the parts around. Working fine now.
Old 06-14-2017, 06:49 AM   #5
SSTony
SSTony's Avatar
Drives: SS Camaro
Why cant i clear the code? I tried with my diablosport and my odb2 scanner. Wont clear
Old 06-14-2017, 07:01 AM   #6
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Ouch.
Good thing PRAY Performance tests his T/B's before he sends them out.
...just saying..
Old 06-14-2017, 07:26 AM   #7
SSTony
SSTony's Avatar
Drives: SS Camaro
The code seems to have cleared
This is most likely not Katech's fault. These come new and if their is bad run only the Manufacturer is to blame
Will see how Katech handles this.
Old 06-14-2017, 07:39 AM   #8
SSTony
SSTony's Avatar
Drives: SS Camaro
Jason from Katech responded emediately and is already sending out a replacement.
Great customer service
Old 06-23-2017, 10:29 AM   #9
SSTony
SSTony's Avatar
Drives: SS Camaro
Katech Throttle body works like a charm now
Old 06-23-2017, 12:40 PM   #10
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
Also, supposed to change the gasket every time. Not reusable, even though it is silicone.
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 06-23-2017, 01:20 PM   #11
SSTony
SSTony's Avatar
Drives: SS Camaro
I did not replace the gasket but so far so good.
Old 06-24-2017, 09:36 AM   #12
KILLA BEE
Black lightning
KILLA BEE's Avatar
Drives: 2021 ZL1 1LE A10
Welp, I was gonna go with Katech until now. Becuz you dont have to worry about any core. Guess pray it is!!!
[ 2021 Camaro ZLE 10 speed
KILLA BEE is offline   Reply With Quote
Old 06-24-2017, 11:02 AM   #13
SSTony
SSTony's Avatar
Drives: SS Camaro
There is nothing wrong with the Katech. They are brand new and there was a bad run. Jason from Katech took care of everything.
Old 07-31-2017, 07:56 PM   #14
Racer Ed
Drives: 2016 Camaro 2 SS
Are you supposed to disconnect the Battery ?
Racer Ed is offline   Reply With Quote
