Old 06-11-2017, 07:54 AM   #1
bryguycbr
bryguycbr's Avatar
Drives: 2016 2SS Nightfall Gray
Send a message via Yahoo to bryguycbr
Dealer fixed warped rotors, no charge
Stonebriar dealer in Frisco, TX, fixed all rotors, refinished front and rear rotors due to excessive runout, lateral runout s/b .002" or less is spec......mine measured .006, .005, .008, and .006, for left frt, right frt, left rear, right rear. I only have 13000 miles, No charge for all work, they covered work under factory warranty. I talked with their brake tech, He's seen the same thing happen to many corvettes with low milage also, he agreed with me about GMs shitty rotor design.
2016 2SS, Nightfall Gray Metallic, Jet Black Leather, A8, MRC, Clear-Bra, ROTO-FAB CAI sound tube removed, Stainless Works Catback with AFM valves, ORACLE ghosted sidemarker set
bryguycbr is offline   Reply With Quote
Old 06-11-2017, 08:46 AM   #2
Sftshldr
Beast Rider
Sftshldr's Avatar
Drives: 2017 ZL1 BLK A10
Sounds like you have a great service department at your dealership.
"Just looking fast is sometimes all it takes!!!"
Sftshldr is offline   Reply With Quote
Old 06-11-2017, 10:51 AM   #3
bryguycbr
bryguycbr's Avatar
Makes me think, they are sticking it to GM using the factory warranty to fix things, regardless, they've fix numerous item using the warranty, some of the problems introduced from me ie: Stainless works catback caused 02 sensor, and left side cat, all replaced free of charge.
