Old 06-10-2017, 03:01 PM   #1
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
HOW TO: SS Hood vent retrofit into LT Hood
So AlphaCamaro7 came up, and this crazy Samoan had an idea. Lets cut hood vents into our cars. We both had the idea for a few months now and there's a post in cosmetic section about it but the guy never got around to it.
No worries, I'd figure this to be easy as I snuck a GT500 hood vent into my 2007 charger hood. blasphemy? I don't care... FUNCTIONAL. that's my goal, get the heat out!
So to start on this, you can make a template many ways.
I basically started with the original outline of the actual vent. easy to trace, and then measure from the edge of the vent to how far in to the clips. the front half of the vent where the water drains, its EVEN all the way around. But the bottom half of the outline will have 3 sections where the clip is actually a bit LESS of an indentation.
By the time today came around, I stopped at FedEx/Kinkos to use the cutting machine, cutting board and duplicated the original template.
there's a small trick I learned after the only mishap on mine. and its due to cheap tools, which I'll gladly point out shortly. I made sure to work on mine first, so no F-ups would be done to anyone else's car. being a car guy, I can live with scratching, denting, my own stuff. Not cool with doing it to someone else's car, especially when it would be learning on the first car, then perfecting by the second car.
so here's the final version of the Hood Template.
now to make this even easier, see the parts where the TAB goes... instead of doing the cutting for the tabs, first, make the inner perimeter all the way around the same distance, like at the top.
Then after you make the outline of where to cut, where the tabs go, just dremel sand away an extra mm or so. this will make it far easier than going in and out, in and out where the tabs go.
Now once you have a template, keep the inner and outer template together. the inner line where you cut, don't cut 360 degrees around. leave just the ends (curved sections) attached. this will keep everything located. you can score or trace the inner line of the template by eye
1st step, once you got everything is removing the under hood liner. the areas to cut are already there. and unlike the 5th gen, there's NO inner hood structure to cut through as well. just an open single panel. use a trim tool, or panel fastener remover.
once that's out, be careful removing it, it CAN and WILL TEAR if forceful.....place your template in that area, and tape it there. afterwards, I drilled 3 holes spaced out. it'll make sense shortly.
So now that you have the 3 holes drilled as you can see above on the underside, there will just be 3 holes on the top side
flip the template over 180 degrees and now you can transfer the same template from underneath to on top. use pegs, screws, dremel bit to put in the template holes and align it on top. tape the edges if need be to make it easier to stay put.
I had a spare under bumper screw from when I added the splitter, a self tapping screw, and a dremel bit of 1/8 diameter that I put in the 3 holes.
So after all is aligned, just start cutting on the line, all the way around... eventually once all is cut, you'll "have a hole in your hood"
But then, you can plug something in the hole.
Basically you repeat the same for the opposite side. also you can cut the peg tabs off the ends. its there for alignment, but its extra holes you gotta drill in the hood.
As for the under hood liner.... easy, no brainer. its already scored on where to cut. and to show how easy it is, I have a key knife. looks like a key, in the middle there's a small utility knife. that's what I used to cut out the felt liner thingy for fire suppression and noise reduction.
Now that you got it cut, put the hood liner back in, there's 3 tabs near the bottom to put in the back of the hood. helps with alignment, so don't bend em. and just lift the hood back in place and reinstall the 7-9 hood fasteners.
Now that I had the first car, MINE done, out the way and learned from mistakes....aka don't use cheap harbor freight diamond disc cutting tools on aluminum metal.
even though it said it could be used, they didn't cut nearly as good as I would expect "diamond" to cut. so I rang up ETMX183 from Camaro5 forums, and he gave me the tip to use the dremel carbon based cutting discs. not the really thin cheaper ones that are dime size, but these are about the size of a silver dollar. this is the exact pack I bought... about 23$ at ace hardware.
After the mishap of the harbor freight gimmick, heating up, and the shaft bent to an L shape and thumped my hood, the dremel did the job 10 times quicker, cleaner, and smoother. I spent about 30 min to cut 5 inches with the harbor freight ones, and I spent about 10-15 min each for the rest of the 3 hole openings I had to cut (right side of my hood, and both for AlphaCamaro7's hood) So lesson learned. His hood though, quick, and NO CASUALTIES
Once I cut Alpha's hood, we stopped by the car wash, and cleaned up the cars. if anyone knows me, they know I wash my car less than I drive it. my car exterior is always dirty, but I use my cars. not a toy, etc. sees track time, I expect the chips, and etc. so I know if I worry about dirt and chips like some do, as much as I use my car, i'll never be happy. and if I'm not happy, I lose interest in whatever that may be. But I got my monthly wash done due to the abrasive dust needing to be cleaned off and all.
Overall, this was pretty easy to do. The one casualty I had was due to a cheap part failure, and to me, I barely notice it. i'llget the touch up paint in a few days and try it. not gonna bother me one bit though either way. my hood NOW LETS OUT HOT AIR
in the words of which I stole from Samuel L Jackson......SH*TCHYEAA!!!
That was my main goal to be honest.
I got a quote from a few places for an SS hood, which was 800$ unpainted, but shipped. paint is another 3-400$ locally for hoods, and the vents were 100$ shipped. Thank you Camar05 for the sale on the vents! But I'd still be at about 1300$ for a new SS hood, and no guarantee on color matching with the new paint, not that I care. (Once again, I'm not particular unless I ask for HBM and you give me Blue Ray Metallic.)
There's also a HBM SS hood on eBay. 499$ but local pickup about 2.4 hours from here, so I'd have to find a way to take this hood off, drive up without a hood and get that one...legally through 3 states. too much of a risk for me.
So the hood vents (100), dremel discs (23) and the cheap cutting discs (12) and a converter I needed (16)...roughly 150$
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 06-10-2017, 03:45 PM   #2
NCSD
Drives: Nightfall, 2SS, A8, MRC, NPP,RE-71R
WOW .. You are a brave man. It looks great good job. I'd be afraid to try that.
NCSD is offline   Reply With Quote
Old 06-10-2017, 04:51 PM   #3
Zae757
Drives: 2016 Black 1SS
Looks good
Zae757 is offline   Reply With Quote
Old 06-10-2017, 05:29 PM   #4
chris227
chris227's Avatar
Nice job. Looking forward to the write up. Looks great.
Old 06-11-2017, 09:27 AM   #5
chris227
chris227's Avatar
So i'm guessing you just used some 3M tape to hold them down?
Old 06-11-2017, 09:44 AM   #6
Drives: 2016 camaro
appreciate it. just look at it as, its my car, if I mess up, I can always fix it
Originally Posted by Zae757 View Post
Looks good
Def Appreciate it!
nope, clipped right in. I'm debating on leaving em like that, or making tabs underneath to attach to the bolts, which is totally doable BTW. you'd simply use a strip of aluminum and drill a hole for the bolts on one side, and then rivet it to the underhood structure on the other side.
each vent would use 2 strips. one coming from the left side of each vent, and one coming from the right side. the same way it is on the stock SS hood. so that would be 4 strips total.
I may put some foam tape under there, like a one sided tape. we talked about the 3m tape though. apparently some have said that's how it comes from the factory. so I haven't ruled that out yet.
Old 06-11-2017, 09:58 AM   #7
chris227
chris227's Avatar
Got it. Gonna have to do this this summer. I did it on my 5th gen with the SS vent.Was curious how it would secure down since i did the what amounted to aluminium straps on my 5th. Thanks again for the great write up.
Old 06-11-2017, 10:31 AM   #8
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
That looks real nice........I know the feeling, you kinda hold you breath when cutting the hood:
Old 06-11-2017, 05:43 PM   #9
Nfg2ss
Drives: 2016 NFG 2SS
Takes some serious balls to do that shit to your car, especially on the hood. ���� Looks awesome.
Nfg2ss is offline   Reply With Quote
Old 06-12-2017, 11:04 AM   #10
Drives: 2016 camaro
Notta prob. Wanted to get it done so we'd know for sure it can be done.
Next goal is to ooen up the drip tray a bit
You shouldnt have any probs though. From doing it on another car itll all come back
Good stuff Glen! Yea you got that "boho pucker" moment, then the rest is easy!
Appreciate it. Honestly i look at it loke bakong a cake or cookin food. If you dont take your time and pay attention, then you can burn it or go wrong. Same with the hood. Just have confidence!
Old 06-12-2017, 11:07 AM   #11
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
I have cut two hoods now and if you arm yourself with one fresh bimetallic blade per opening, the hood really does cut almost like butter.....
Old 06-12-2017, 11:23 AM   #12
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Very nice job!!!!
Old 06-15-2017, 09:40 AM   #13
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
1) This is pretty awesome in terms of DIY!
2) Where the hell do you find pants to contain your giant brass balls?!
Nice work man, really!
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 06-27-2017, 11:02 PM   #14
Phoenix_Gilmore
Phoenix_Gilmore's Avatar
Drives: 2020 2SS
I'm about to do this to my LT. Any tips?
Phoenix_Gilmore is offline   Reply With Quote
