![]() Drives: Red hot 2017 ZL1 Join Date: May 2017
Front suspension "CLUNK"
has anyone had problems with a clunk sound on the front suspension?
Every time I back out of the garage, and the front wheels fall off the little 1" ledge between my garage floor and driveway, I get a clunk. No other symptoms and I've largely ignored it since my 1LE did the same thing.
Clear Bra, Tint, Splash Guards, Ceramic Coating, Painted Spoiler and Rear Views
![]() Drives: Black SS 1LE Join Date: Mar 2017
Guys if it's not too late, you need to tighten your end links, or go to the dealer for warranty work. It's becoming a common issue.
Loves Camaros
Drives: Red '79 Z28, '24 Blk A10 ZL-1 Vert Join Date: Sep 2012
Most common is driver's side sway bar link. Mine did it, and I had to retorque and locktite!
Old and new, sharing space!
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
Common suspension "clunks" react different or not at all if it is a "fall" or a bump. Most times you notice on a fall
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
#7 |
retorqued both end links noise is gone!!! thank you guys
#8 |
what did you actually tighten?
Current ride
#9 |
#10 |
![]() Drives: 32 Ford 55 Nomad 69 Ve 14 M5 17 ZL1 Join Date: Dec 2016
GM Bulletin confirms 2017 ZL1 has common problem of Sway Bar Link coming loose.
EVERYONE TAKE YOUR CARS IN!!! |
#11 |
![]() Drives: 2017 ZL1 6 spd RED HOT w/ PDR Join Date: Oct 2016
What torque should we tighten to? Don't want to take it back to the stealership unless I really have too...
#12 |
![]() Drives: 2017 garnet red zl1 2022 AT4 HD Join Date: Nov 2016
Just got my zl1 back from getting the end links tightened up again. Seems like a common issue.
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: X-15 Velocipede Join Date: Mar 2008
#14 |
Loves Camaros
Mine just started rattling again. I retightened them and used LockTite Red. It lasted about a month, but started rattling yesterday. Argh!
