Old 06-08-2017, 03:33 AM   #1
BIGG_FRANCO
BIGG_FRANCO's Avatar
Drives: 2017 camaro
6th Gen trunk
Anybody else getting their trunk stuck when trying to open it? Its starting to annoy me it's happening one two many times...Any fixes?
BIGG_FRANCO is offline   Reply With Quote
Old 06-08-2017, 08:11 AM   #2
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Yeah, this happens to me at times. When I push down on the edge and hit the button it always opens. I recently adjusted the rubber bump stops on either side of the trunk opening by turning all the way left. It seems to have done the trick. You may have to play with them to get the right setting for yours.
Old 06-08-2017, 11:26 AM   #3
BIGG_FRANCO
Drives: 2017 camaro
Ok thank you I'll try that it was embarrassing showing a friend the car and the trunk wouldn't open
Old 06-08-2017, 12:19 PM   #4
Michigan1LTRS
Blessed ❤️
To be clear on the bump stops. I said turn left. What I mean is I turned them all the way down, but again you may need to play with the adjustments.
Old 06-08-2017, 07:24 PM   #5
BIGG_FRANCO
Drives: 2017 camaro
Old 06-09-2017, 11:32 AM   #6
DarkFangz1100
Drives: 2016 Camaro SS
Do you have a spoiler? I put a the ZL1 on my car with the original supports and the trunk wouldn't open sometimes...luckily I bought the correct ones at the same time I was just trying to see the difference at the time.
DarkFangz1100 is offline   Reply With Quote
Old 06-10-2017, 12:31 PM   #7
BIGG_FRANCO
Drives: 2017 camaro
No spoiler bro
Old 06-13-2017, 03:11 PM   #8
Nate...
Nate...'s Avatar
Drives: 2016 Camaro LTG
No spoiler bro
Did you adjust the bump stops? Did it work?
2016 LTG Camaro in Hyper Blue with MRT V3 Catback and Brembo SS Brakes.
Nate... is offline   Reply With Quote
Old 06-13-2017, 03:45 PM   #9
DeliveryMan
check the striker in the trunk, it could also be lose
DeliveryMan is offline   Reply With Quote
Old 06-14-2017, 12:33 AM   #10
BIGG_FRANCO
Drives: 2017 camaro
Tried turning them they keep rotating thought it worked till this morning it had gotten stuck again..
Old 06-14-2017, 12:34 AM   #11
BIGG_FRANCO
Drives: 2017 camaro
What does that look like?
Old 06-14-2017, 09:16 AM   #12
DeliveryMan
Bigg Franco
The Striker is the piece that the Latch of the hood latches onto when it closes.
So if you are looking in your trunk it is in the middle of the tail lights. On the inside of the trunk. it looks like a squarish hook or a chain link.
It's a simple piece, but it needs to be tight and secure. it's something you can try first before taking the car to the dealer.
here is a link to what it looks like.
https://www.google.com/search?q=trun...=1497446056837
Old 06-14-2017, 09:54 AM   #13
BIGG_FRANCO
Drives: 2017 camaro
Bigg Franco
Thank man I'll give it a shot
Old 06-16-2017, 06:35 PM   #14
DeliveryMan
Bigg Franco, how did it go? any luck
