Old 06-08-2017, 02:18 AM   #1
ULTRAZLS1
ULTRAZLS1's Avatar
0-60 in 3.5 on the street...what you got ?
Let her eat on the way home from work tonight with the drag pack on. Used launch control and it worked pretty good. Only slight bog. Hit 60 without another shift with my raised shift points working properly now. This wasn't an exaggerated time due to spinning. Car was hooked when I hit 60...
At the track I've got to be in the very low 3 second range just going off of feel
Who's got me beat? Let's see it...
Old 06-08-2017, 11:57 AM   #2
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
What is the drag pack on? Launch control?
drivingagain is offline   Reply With Quote
Old 06-08-2017, 12:11 PM   #3
Snowblind
Snowblind's Avatar
Are your DR's the same height as your stockers and did you recalibrate the speedo ? I get 4.4 at the strip without a recal.
Usually a skirt and heels
Old 06-08-2017, 01:07 PM   #4
ULTRAZLS1
ULTRAZLS1's Avatar
They are close to stock height. Haven't measured but according to the numbers stock is 27.6 and the dr is 27.8
Old 06-08-2017, 02:20 PM   #5
drivingagain
Ok so you are stating drag radials as a drag package? I ask as there is no drag package but maybe a product I was not aware of.
Old 06-08-2017, 02:29 PM   #6
ULTRAZLS1
ULTRAZLS1's Avatar
Drag pack is a term for a wheel and tire setup for drag racing. Typically smaller diameter, skinny in the front and wide in the rear.
My drag pack is 17 inch wheels and 305/45/17 drag radials in the rear
Old 06-08-2017, 02:43 PM   #7
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
4.4 in my automatic 4 banger
Old 06-08-2017, 03:24 PM   #8
PRAY
PRAY's Avatar
Drives: 2016 2SS
3.3 on the stock converter is the best I ever saw. If I saw a 3.4 I knew it was a low 11.1 pass. Never checked it with the converter though. Your tires are skewing the time. On the car they are a about .75" taller than the stock tires. So...you actually get to 60mph faster than that. Congrats. What did you finally get the 1/2 and 2/3 to shift at?
Old 06-08-2017, 04:20 PM   #9
ULTRAZLS1
ULTRAZLS1's Avatar
6700 was the goal. Looks pretty close to that looking at the dash. Haven't personally checked the log with newest trans tune
Old 06-10-2017, 07:53 AM   #10
PRAY
PRAY's Avatar
Drives: 2016 2SS
Nice, glad you are getting it dialed in. That should pick up the "loss" you had on the front half.
Old 06-10-2017, 08:23 AM   #11
wnta1ss
Drives: 2017 Camaro 1SS
I have the same size MT DRs (305/45-17), and noticed the speedometer reads a touch low when they're mounted. MT lists them as 28.1" diameter. The 'hold 4th gear' discussion sheds some light on this, as stock car hits limiter around 111~112 on stock tires, and these tires allow 116 in 4th.
Old 06-24-2017, 10:16 AM   #12
jrs580
jrs580's Avatar
Drives: 2016 2ss
I finally pulled one under 4 seconds with street tires.
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in.
jrs580 is offline   Reply With Quote
Old 06-24-2017, 08:24 PM   #13
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Did you use launch control?
cmitchell17 is offline   Reply With Quote
Old 06-25-2017, 09:35 AM   #14
jrs580
jrs580's Avatar
Drives: 2016 2ss
Yes I did. I found a good concrete launch area and it made all the difference.
