Old 06-06-2017, 06:45 PM   #1
soceur77
Drives: 17 NFG ZL1 17 GTR 22 RS6
Reverse tilt mirrors
Is there no way to set where i want the mirrors to stop? I find they go down way too far for my liking. I like to see the curb and the bumper of a car behind me.
soceur77 is offline   Reply With Quote
Old 06-06-2017, 07:39 PM   #2
USP45
Drives: 2017 ZL1 A10
If you find it I would love to know as well, I agree with you.
USP45 is offline   Reply With Quote
Old 06-06-2017, 07:46 PM   #3
flyinlow
flyinlow's Avatar
Drives: 2017 Camaro ZL1
There isn't, only option is to have it tilt or not tilt. It tilts down quite a bit so you can see your wheel and the curb, that's the purpose of it tilting.
flyinlow is offline   Reply With Quote
Old 06-06-2017, 07:48 PM   #4
Zack46
Zack46's Avatar
Zack46
Production Sequence Number 98
NEOCC Camaro Club Member
Old 06-06-2017, 08:53 PM   #5
crossroaddemons
Drives: 1971 Chevy Camaro
I've noticed the mirrors return to their normal position a short time after reversing. I'm not even out of the garage when they tilt up
crossroaddemons is offline   Reply With Quote
Old 06-06-2017, 09:03 PM   #6
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Is this a ZL1 only feature?
G2K is offline   Reply With Quote
Old 06-06-2017, 09:41 PM   #7
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
i wish. the best thing ive found is just have one tilt i guess
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 06-06-2017, 09:47 PM   #8
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
My mirrors don't tilt in reveres. I need to figure that out.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 06-06-2017, 10:00 PM   #9
USP45
It is in the settings menu. You can choose no tilt, either the drivers or pass only tilt in reverse, or both. I currently have mine set to both, but they DO tilt at a pretty good angle to where you can see the wheel very well, but not much behind you. I think I might change mine to just the pass side since I normally try to back in with the pass side next to a curb (don't want to chance opening my door into a high curb) and I certainly want to see where the passenger side rear tire is in relation to the curb.
Sure this is a very minor annoyance, but I too would like to be able to set the tilt angle. Oh well, in a perfect world!
Old 06-06-2017, 10:24 PM   #10
Ron_Robinson1
Thanks. I will check that out.
Old 06-06-2017, 10:31 PM   #11
TJay74
There is a timer out limit on the reverse tilt function, so they will return back up if you stay in reverse too long.
Old 06-07-2017, 08:49 AM   #12
Hellobatman
Hellobatman's Avatar
Drives: 2017 Ford F250, 2019 Lincoln Navi
I used to have a 2004 BMW coupe that did it on the driver's side. Was a great feature when backing up next to a curb. My ATS-V has the same feature as our ZL1's, couldn't be happier with it. Absolutely NO reason for curb rash on these wheels!
Instagram: MattZ_L1 Vengeance Racing Built
Hellobatman is offline   Reply With Quote
Old 06-07-2017, 09:02 AM   #13
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
My wifes 2014 impala has this same feature. I hate it. So no it isnt just a ZL1 feature.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 06-07-2017, 09:30 AM   #14
Walkure
Walkure's Avatar
Drives: '17 ZL1 A10 Vert
I don't have my Camaro yet so I can't test it out, but here's how my Mercedes C350 works:
If you put the car in reverse, the passenger mirror tilts down. While still in reverse, you can adjust the mirror using the normal controls. Once you have it in the preferred position, save it to your programmed seat/mirror settings.
From then on, it only tilts down to the position you saved, and then back up to your normal position when you shift out of reverse.
Walkure is offline   Reply With Quote
