Old 06-05-2017, 08:44 PM   #1
lcarney1977
Drives: 2016 CAMARO SS
E85?
does anyone know if you install the E85 flex fuel kit that you can fill up even if you have some 93 in your tank, and then the tune pks up when the E85 comes in? so if im running 93 and find E85 on the road i can mix it and be ok thats how it works? also cause im procharged im gonna add the LT4 HPFP and the LPFP and the E85 kit im making 565whp now what can i expect form this upgrade thx...
lcarney1977 is offline   Reply With Quote
Old 06-05-2017, 09:08 PM   #2
parish8
Drives: 17 SS a8
the flex fuel kit and required tuning takes care of you no matter what ratio of ethanol you decide to run. you will gain lots of hp when running the e85 and it will go away when you are not.
the problem is you probably wont have enough fuel system even with the upgrades to run e85.
I have the lingerfilder hpfp, lt4 injectors and the zl1 intank pump and I am can not run over 6psi without running out of fuel while on e85. I dynoed 590rwhp on a dynojet at 5psi and could probably get another 30 hp if I pushed it to the limit. there are ways to get more fuel like a more robust low side and a larger fuel lobe on the cam. many go with meth. I am doing an over the top port fuel injection set up.
