Old 06-04-2017, 08:40 AM   #1
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Procharger P1 installed but not doing so well..
Just in case anyone has any guesses as to what this might be. I'm all out of ideas until I can call them tomorrow.
Got my PCM back from ATI (They have to program them there since it's 2017). Car starts and idles just fine, Rev's fine. Race bypass seems to be open even at idle and just driving out of my neighborhood you basically hear it gushing air. Not at all like I expected it to work but googling the Procharger Race Bypass it seems some Vette forums that it may be working as intended. Basically always open until there's 0 vacuum on the intake.
So I took it out a couple times and eased up to near 3k RPM. The moment I go anything near 3/4 throttle it surges, stumbles and I hear heavy cylinder misfire like if I had went and unplugged 2 cylinders.
I've gone and checked just about everything I can at this point. No boost leaks so I'm left just wondering if the tune on my pcm got botched.
No check engine light so far either.
Dysan911 is offline   Reply With Quote
Old 06-04-2017, 03:06 PM   #2
Dysan911
Dysan911's Avatar
My Aeroforce Guage caught about 28 misfires during a little quick drive I tried to make. Maybe I should pull the plugs next.
Old 06-04-2017, 03:09 PM   #3
Ponyeatr16ss
retired badass
Ponyeatr16ss's Avatar
Drives: 2016 2SS M6
Send a message via AIM to Ponyeatr16ss Send a message via Yahoo to Ponyeatr16ss
Did you change the plugs? I believe in the install you are supposed to go to a different spark plug
2016 2SS M6 Black
Kooks 2in headers/full exhaust, Hurst short shifter, Dsx E85 kit, BMR solid engine mounts.
Retired USMC
Ponyeatr16ss is offline   Reply With Quote
Old 06-04-2017, 03:22 PM   #4
Dysan911
Dysan911's Avatar
Yes. NGK's 1 step colder and I gapped them at 0.040. Is that too wide?
free image hosting services
Old 06-04-2017, 03:25 PM   #5
Ponyeatr16ss
retired badass
Drives: 2016 2SS M6
The gap should be listed in the instructions
2016 2SS M6 Black
Retired USMC
Old 06-04-2017, 03:27 PM   #6
Dysan911
Dysan911's Avatar
yeah its asking for 0.035 . So im pretty close. I can't imagine being off by 0.005 would create the amount of misfires Im getting.
Old 06-04-2017, 03:29 PM   #7
Ponyeatr16ss
retired badass
Drives: 2016 2SS M6
You might be amazed. Recheck all your boots make sure they popped back in place.
2016 2SS M6 Black
Retired USMC
Old 06-04-2017, 04:24 PM   #8
Johnny45thSS
Drives: 2016 camaro ss
I had this issue
What model number on the ngk 6510?
Try this, install the old ones and do a few runs see if it goes away if it does plugs too cold
Johnny45thSS is offline   Reply With Quote
Old 06-04-2017, 05:37 PM   #9
Dysan911
Dysan911's Avatar
Originally Posted by Johnny45thSS View Post
I had this issue
They're NGK 6510's. I just got finished gapping all of them to 0.035 fwiw. Car idles fine though. Would too cold of a plug only affect 3/4 to full throttle?
Old 06-04-2017, 05:46 PM   #10
lcarney1977
Drives: 2016 CAMARO SS
i have a D1 procharger and evrything is fine until i go on the highway and go in 3rd or 4th gear punch it and it picks up nice then all the sudden it surges real fast like almost stall feel for like quick mil second. i had a place check the tune and he said it was the air fuel ratio not getting enough fuel up top, so he tunes it and says it should be better i go home drive on the highway and it still does it so annoying that tuners cant find whats wrong,,
lcarney1977 is offline   Reply With Quote
Old 06-04-2017, 05:54 PM   #11
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
This maybe totally unrelated but just reminded me a little of this thread.
http://www.camaro6.com/forums/showthread.php?t=490819
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 06-05-2017, 07:31 AM   #12
Dysan911
Dysan911's Avatar
Update: With the help of several folks we tracked the issue down to Cylinder 7. Turned out there was a cracked plug and an issue with the MAF Extension wire.
I put in a stock plug on #7 and took the maf extension apart to pull the pins back into alignment.
Took it for a test drive and finally got to experience the power!.. What a difference. No misfires, No kock, just warp speed.
I did get a couple DTC codes though. One regarding the TPS Sensor and 2 others regarding the Barometer sensor. I do. or should I say now 'DID' have a vitesse controller on the car. I don't know if somehow that causes the TPS Code. The other two codes will occur if:
P2227 trouble code definition
Either the barometric pressure sensor is providing a reading that does not correspond to the parameters of the ECM about the atmospheric conditions, or the output of related sensors such as the throttle position sensor or manifold absolute pressure sensor do not correlate.
We will see if it goes away now that it's removed. If not I might need a new maf extension cable from ATI.
B.
Old 06-05-2017, 07:36 AM   #13
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
If I recall correctly, I had the same code issue with my '16. Let ProCharger know. Mine was an issue with the tune that they sorted out.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 06-05-2017, 07:38 AM   #14
Dysan911
Dysan911's Avatar
Ahh ok will do!. THank you for letting me know.
The codes I keep getting are
p0121
p2227
p2229
