Old 06-03-2017, 02:34 PM   #1
mrtoner
mrtoner's Avatar
Drives: 2016 SS Nightfall Gray
UPDATE - One Headlight LED DRL is out
Just noticed yesterday that my right headlight LED DRL is not on. Car looks like it's winking....
I tried to find the connection to see if something got loose, but I don't see much access to the headlight assembly.
Any ideas? Otherwise I'll do the dealer thing.
So I took it to the dealer to fix since it was also time for an oil change.
Apparently this doesn't happen often, according to my service guy, and I had to wait 3 days for a replacement headlight to come from a warehouse somewhere back east. No problem for me since I work out of the house and I have the Tahoe as a second car.
It took the tech 30 minutes to swap out, but that headlight cost .... wait for it.......$975!!!!!!
Good thing it is covered under warranty...
Works perfect now, as it should. Just rolled 6,000 miles and no other issues.
mrtoner is offline   Reply With Quote
Old 06-04-2017, 05:57 PM   #2
mrtoner
mrtoner's Avatar
To the top....
Old 06-04-2017, 08:02 PM   #3
interceptor
interceptor's Avatar
Drives: Stock '17 2SS M6 50th - DD '99 F150
Originally Posted by mrtoner View Post
To the top....
DRL LEDs are self-contained within the sealed headlamp assembly. If you're still under warranty, let the dealer take care of it.
interceptor is offline   Reply With Quote
Old 06-05-2017, 12:02 PM   #4
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Was your turn signal on?
On my Gen5 when turn signal is on it looks like it is winking since the light shuts off at that time on that one side.
Thought it was defective but then found out it was suppose to go out when the turn signal is on.
Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 06-05-2017, 12:48 PM   #5
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
DRL goes out if turn signal is on. comes back on after blinker is de-activated
nancygrl is offline   Reply With Quote
Old 06-05-2017, 01:08 PM   #6
mrtoner
mrtoner's Avatar
Nope - turn signal not on - first thing I checked.
Old 06-05-2017, 01:26 PM   #7
Sftshldr
Beast Rider
Sftshldr's Avatar
Drives: 2017 ZL1 BLK A10
Gen5DIY has some good pictures around the headlights and eyebrows in the instructions tab at http://www.gen5diy.com/Chevrolet/Cam...brow-Harness8/
This won't probably fix your headlights, but will give you an idea maybe of what you would be getting into in checking if your harnesses are tight.
or a direct link to the pdf instructions.
http://www.gen5diy.com/image/data/Car Manufacturer/Chevrolet/Camaro G6/Install PDFs/Gen6wheelwellliner.pdf
http://www.gen5diy.com/image/data/Car Manufacturer/Chevrolet/Camaro G6/Install PDFs/Gen6EyebrowHarness.pdf
"Just looking fast is sometimes all it takes!!!"
Sftshldr is offline   Reply With Quote
Old 06-13-2017, 10:55 PM   #8
mrtoner
mrtoner's Avatar
Had no choice but to take it to the dealer, but I have always had great service and not one issue there with all my cars.
So, yes - the front fascia has to come off to replace the complete headlight assembly.
So, we'll see.......
Old 06-16-2017, 10:07 PM   #9
mrtoner
mrtoner's Avatar
Old 06-21-2017, 06:23 PM   #10
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
As some of you know we sale a head light kit and what we found out last week is that this may have been a bad DRL controller, we had one do some thing like this on a costumers cars, they had one one bright in the day time and it went to low at night, the other side went to low in the day time and stayed there.
The way it works is the car drops the V+ to 5V on the DRL in the night mode and its 12V in the day time by seeing this the controller works all 4 DRL lights.
That bad controller in the headlight may be the same thing your headlight had or it was completely bad.
2SSRS@Gen5diy is offline   Reply With Quote
Old 06-21-2017, 07:00 PM   #11
i007spectre
i007spectre's Avatar
Drives: 2016 2SS, 2008 HHR ECTO-2H
My car arrived from the factory with a headlight out. Took almost a week for my dealership to get a replacement in.
2016 Camaro 2SS. Hyper Blue, Ceramic White, Auto, MRC, and NPP.
1100 - 9/25
2000 - 9/28
3000 - 9/30
3100 - 10/27
3300 - 10/28
3400 - 10/29 TPW 11/09
3800 - 11/10
4300 - 11/24
4B00 - 11/25
4200 - 12/5
5000 - 12/7
6000 - 12/11
i007spectre is offline   Reply With Quote
