Old 06-01-2017, 04:10 PM   #1
gilgamesh
Drives: 2015 Charger SRT Hellcat(732rwhp)
Need dyno help
About to strap my 17 ZL1 Down. What settings do I need to be in for a good dyno pull? 6m
Rides-
2015 Hellcat Charger-732rwhp/708rwtq
2017 ZL1 6M- Rotofab CAI, Katech ported Tbody
gilgamesh is offline   Reply With Quote
Old 06-01-2017, 04:12 PM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 06-01-2017, 04:48 PM   #3
gilgamesh
Thanks, very helpful!
Rides-
Old 06-01-2017, 04:58 PM   #4
Zl1steve
Drives: Zl1
Turn off traction control and put it in track mode. Good luck man!!
Zl1steve is offline   Reply With Quote
Old 06-01-2017, 05:00 PM   #5
Zl1steve
Drives: Zl1
And dyno in 7th gear manual mode.
Old 06-01-2017, 06:01 PM   #6
dicebier
Drives: 2017 ZL1
Jeez, give the guy a break! The OP said it was an M6, use 4th gear as 1:1 for true numbers (or as true as possible given operator, weather, etc... also if it's a dynojet shut off traction control and put it in track, if it's a mustang dyno, hold button for ten seconds and shut ALL NANNIES OFF. MAKE SURE ITS STRAPPED DOWN PROPERLY IF YOU DO THIS. In any case, the dyno operator should know what to do, he's liable anyway if anything happens (shouldn't btw), stock manual should put down 550 range HP and appx 560 range torque give or take. Good luck man , hope you get a great pull! Roto Fab may increase these numbers by 20 each, maybe
dicebier is offline   Reply With Quote
Old 06-01-2017, 06:27 PM   #7
Shorty45
Shorty45's Avatar
Drives: 2017 Summit White ZL1, M6
I second that! Btw, I just installed the Roto fab and it's definitely helped throttle response. Also, the blower sounds awesome, especially WOT down a track. Cheers and put up good numbers!
2011 Dodge Ram 1500 Longhorn Laramie
1966 Chevelle SS 396
Shorty45 is offline   Reply With Quote
Old 06-01-2017, 06:36 PM   #8
dicebier
Drives: 2017 ZL1
Honestly, I wouldn't even dyno it, I'd just run a driving diagnostic, no tune just data log and have a pro check it out. But if you must just to know then go for it. Remember that the hp/tq numbers will vary between runs but the curve should be similar in all runs
Old 06-01-2017, 07:43 PM   #9
Dethsupp0rt
Drives: None
I think I need one of these. I can hear the blower when I'm just tooling around slowly, but it's hard to hear it when you're WOT because the engine noise drowns it out.
If it's really that much better, I'm down for it.
Dethsupp0rt is offline   Reply With Quote
