Old 06-01-2017, 11:11 AM   #1
JANNETTYRACING
JANNETTYRACING's Avatar
JANNETTY RACING SCT CUSTOM TUNE INSTRUCTIONS REV 2017
JANNETTY RACING CUSTOM TUNE INSTRUCTIONS
When you purchase an SCT X4 hand held tuner or any SCT device from me, you get One 93 or One 91 Octane tune for stock vehicle equipped with any CAI and any Cat Back for your 2010-16 Camaro FREE.
EXCLUSIONS apply for headers, cams, superchargers, nitrous and other vehicles. Custom tuning for excluded items are available at an additional cost. See options on our website or contact me via e-mail for a quote.
Additional tunes with minor changes are available AT THE TIME OF PURCHASE for $60.00 and up, each. i.e. a second tune for 91 Octane.
Your new SCT X4 will come to you blank. You will need to connect the device to your car and upload the stock tune file. Here is how: 1) Sit in the car 2) Close the door 3) Turn off all accessories and unplug any devices from the power ports I.e. cell phones, radar detectors, navigation etc. 4) Plug the device in to your OBDII port 5) Select Program Vehicle. 6). use the down arrow and scroll down to UPLOAD STOCK. It will prompt you to turn on the key. 7) Turn the key on, but do NOT start. 8) Wait for the dinging to stop and hit select.
Note 1: Upload Stock will not disable your vehicle it only makes a copy of the stock file.
Note 2: On some vehicles, you may get prompted to make a selection of ECM and TCM The 2010-2015 Camaro uses E-38 and None for manual cars, E-38 and T-43 for automatic cars, for other vehicles call or email me.
To get the tune file off the device you will need Software called SCT Device Updater software. https://www.sctflash.com/support and download the software for FREE. Install this in your home or laptop computer before you connect the device to your computer.
After you install the software, open it up and connect your SCT device to your computer. The drivers should install automatically. Then, click on ‘Get Stock File’, click browse, find your desktop, and then click save.
On your desktop there will be 2 to 3 files. ONLY Select the one with your VinNumber.sul and email it to me at tedj@jannettyracing.com along with your full name, address, phone number(s), and all vehicle information. Year, make, model, engine, transmission, list of performance modifications and preferred octane of your choice. Most common are 93 or 91.
Please include cold air kit brand and part number if equipped.
*PLEASE RE READ LAST STEP! I CANNOT TUNE YOUR CAR WITHOUT THIS INFORMATION. EVERYONE SEEMS TO FORGET OCTANE REQUIREMENT.*
Once I receive an e-mail with all of the vital information, I will then send you back a custom tune file for your modifications.
When you receive a response, save the file to your desktop. The name of the file will be YOUR NAME JRE TUNE.cef
Again, open SCT device updater software. Connect your SCT device and select ‘Load Custom Tune File’. Browse to your tune file and select it. Then, select a position 1, then name it anything you like. I.E. ‘JRE Tune’. Click on program. You will see the progress bar at the bottom go green. Exit when finished.
Connect to your car. Select ‘Program Vehicle’, scroll to Custom Tunes, select ‘JRE Tune’ and follow the on screen prompts.
Data Logging
I have developed dyno proven tunes for all of the products I sell. Unless I instruct you to do so, data logging will NOT be necessary.
If I instruct you to data log your car, you will need LiveLink Gen II software to do so. You can download the software free here: https://www.sctflash.com/support
The best way I’ve found to data log is to use a laptop on the seat. First, start the car. Next, open the LiveLink Gen II software. Then, connect the X3 or X4 to your laptop. Then, connect the X3 or X4 to the OBDII port of the car. Start the car, Then, you will follow the on screen prompts. (I want to data log my car) after you have gone through the steps a list of PIDs will come up, you will have to scroll through them selecting the items below.
Even thought they may not be named exactly as I listed them, I want you to select the following. However, try not to select anything that is not listed or anything that are doubles of any of the items listed below.
You may have to test several PIDs to see which ones work best or work at all on your car.
Engine RPM - RPM
MAP-Intkman abs prss
FUEL PRESSURE
ECT engine coolant temp – ecteng clt tmp
TPS throttle position or pedal position – acc pdl pos 1s
IAT intake air temp or Air intake temp – intk Airtmp
MAF Mass Air flow Hz – Maffre 125
TIMING spark cylinder 1 – ign Tim Adv4#1cyl
KNOCK RETARD – knk ret
Vehicle speed Kph–?
Long Term Fuel Trim bank 1 – ltf tri b1
Long Term Fuel Trim bank 2 – ltf tri b2
NOTE, Cars with boost will need an AFR gauge, SCT Firewire, and will need to select the Analog Channel you wired the Wide band AFR gauge to, Either Red or Orange.
Depending on the Brand of gauge you will need to select the tools tab in Livelink Gen II then equations, on the right you will see a list of aftermarket AFR gauges Select your brand and part number, and then apply it to your Analog Channel.
Test the logging to make sure all the PIDs are working, and that the AFR displayed in Livelink Gen II Analog channel, Matches the AFR readings on your Gauge.
If they do not match something is wrong and must be fixed before any logging it done.
Please ONLY select the PIDs listed! Extra PIDs slow down data logging and gives me useless information.
Once you have your PIDs configured and working, you can go to File/save/Configuration, Save to your Desktop for future Logging.
BEFORE LOGGING WITH THE CAR IDLEING, YOU MUST HOLD THE TRACTION CONTROL BUTTON DOWN FOR 8 SECONDS TO DISABLE THE TRACTION CONTROL AND STABILTRAK SO THEY DON’T INTERFERE WITH LOGGING.
ALSO PLEASE MAKE SURE THE CAR IS FULLY WARMED UP BEFORE LOGGING.
Find an open road somewhere, 1/2 mile or so long would be great. From a stop, drive the car about Very light throttle up to 5000 rpm, coast down to a slow roll and repeat 3-4 times, Manual cars do this in 3rd gear, and Automatic cars in paddle mode use 3rd gear on the Gen 5 and 4th gear on the Gen6.
Then repeat about up to 5500 RPM. Speeding is not recommended or necessary.
Boosted Cars; Do NOT go in to boost until I give the OK to do so.
Stop and save the data log as (Your Name log 1.csv) Number each one consecutively and save to your desktop.
E-mail me the log files along with your full name, address, phone number(s), and all vehicle information. I.E. year, make, model, engine, transmission, and a list of performance modifications, octane burned.
Include any comments you may think are helpful!
*PLEASE RE READ THIS STEP, I CAN NOT REFINE YOUR TUNE WITHOUT THIS INFORMATION.*
Please do not assume I will know who you are by your forum screen name, what kind of car you drive, or what your mods are. I deal with 50-100 people per day so I must have all of your info right in front of me in ONE email so I can properly write or refine your tune.
Your cooperation in reading, understanding and following these directions will make this a very pleasant experience for the both of us!
After tuning the light throttle ranges, most bolt on vehicles do not require further data logging.
In the event of Cams, Superchargers, NOS, or combinations thereof, I may instruct you to do wide open throttle runs at the racetrack or on the Dyno with a wide band AFR meter or a vehicle installed AFR gauge connected to your SCT device via a firewire. Log these runs, I will view and refine the WOT part of the tune, and then we are finished.
JRE TUNE UPDATES
Any time requesting tune update due to changes in part combinations you will need to provide me with the following info in order for me to provide an updated tune.
Full name, address, phone number(s), and all vehicle information. I.E. year, make, model, engine, transmission, list of performance modifications OLD, and list of performance modifications NEW and preferred octane.
I do not need your vinnumber.sul file as I have it in my data base.
I need to know if you purchased your new parts from JRE to qualify for the free tune update, proof of purchase like order number or invoice number is required.
Thank you for choosing JRE,
Ted.
FAQ https://www.sctflash.com/support/kno...se?category=X4
www.jannettyracing.com
email tedj@jannettyracing.com
Old 06-07-2017, 01:25 AM   #2
PinHead
Drives: Duramax
Thanks Ted
PinHead is offline   Reply With Quote
Old 06-07-2017, 06:56 AM   #3
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
great post really gives insight to people who are new to tuning how it works and a bit of the behind the scenes.
Dustya is offline   Reply With Quote
Old 06-07-2017, 07:34 AM   #4
JANNETTYRACING
Originally Posted by PinHead View Post
Thanks Ted
You are welcome.
Thank you, Yes sir, I posted this to help answer a lot of the questions I get on a daily basis.
Ted.
Old 06-07-2017, 12:14 PM   #5
NW Sam
NW Sam's Avatar
Drives: 2017 ZL1 Garnet Red
Hi Ted,
We met in Canada back in the diesel days.
I wanted to track my '14 ZL1 but didn't fit with a helmet lol.
I purchased a 2017 Camaro ZL1 Auto without a sunroof.
My friend has a Hellcat Charger and has been King of Mountain for over a year lol.
What do we need to do to this car to be competitive in a straight line?
I have a Rotofab CAI and and ported throttle body so far.
Thanks, Sam.
NW Sam is offline   Reply With Quote
Old 06-07-2017, 12:56 PM   #6
JANNETTYRACING
Originally Posted by NW Sam View Post
Hi Ted,
Thanks, Sam.
Hello Sam,
Small world.
My 750 HP or 830 HP package will do the trick, give me a call to discuss. 203-753-7223
Ted.
Old 06-23-2017, 10:53 PM   #7
STRUGLE
Drives: 2016 2SS Black/Black
Will this tuner support e85/flex fuel ?
STRUGLE is offline   Reply With Quote
Old 06-24-2017, 09:57 AM   #8
JANNETTYRACING
Yes sir it will with my custom tuning for it.
Old 06-25-2017, 12:29 PM   #9
Pckrfan795
Pckrfan795's Avatar
Drives: 2021 Shadow Grey ZL1M6
Pm sent
Sent from my Pixel using Tapatalk
2021 ZL1M6, Shadow Grey
Pckrfan795 is offline   Reply With Quote
Old 07-31-2017, 10:42 AM   #10
JANNETTYRACING
Originally Posted by Pckrfan795 View Post
Pm sent
Got you covered.
Ted.
Old 07-31-2017, 07:04 PM   #11
STRUGLE
Sent you a message. Thanks
Old 07-31-2017, 07:22 PM   #12
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Old 08-21-2017, 11:18 AM   #13
JANNETTYRACING
Thank you.
Old 08-26-2017, 08:13 AM   #14
JANNETTYRACING
Got you answered.
