![]() Drives: 1967 Firemaro / 2017 2SS Join Date: Apr 2017
Track Prep Cost @ Dealer?
Looking to get the track prep work done at a dealer and looking for pricing. 2 Dealers I called said they never did that stuff and one said they Don't do it! Of course these are the Service Advisers... The dealer who said ok, then quote me $800!
I looking for - Differential Service (flush) - A8 Trans fluid track check - Install plastic brake backing plates - flush brake fluid (I was furnishing Castrol) - optionally I was going to have them install braided brake lines I have in hand, since they would be there in the front already. Any input on what you paid or would expect to pay?
Mike Dee
SoCal USA 2017 Camaro 2SS 2015 Corvette Z06/Z07 1975 Supercharged Corvette 1967 Firemaro Show Car - For Sale |
![]() ![]() ![]() Drives: 2019 CLA 450 Mercedes Join Date: May 2016
I might suggest you look at a shop that also does your tech inspections. This will usually be a shop that is well familiar with racing and likely have racers in their staff. I had mine done for $200 labor and I supplied all of the fluids. That included the brake cooling ducts install, torque of lugs and tech inspection. I left my alignment stock as I knew I would not be near the limits of the vehicle. The owner signed the tech sheet and called the track manager, as a courtesy. He is a well known enthusiast who runs a 2015 Z28, in white (a faster color
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red 2014 Lincoln MKT EcoBoost (The Bus) |
Thanks for the input. I need to shop around a little bit and see who's qualified. I'd like to find a shop that has a racer involved.
Mike Dee
#4 | |
In my case, I live too far from the track and there were none listed in my area. However, I knew the shop owner from Cars and Coffee. The rest was that easy.
![]() ![]() Drives: 2016 1ss Camaro Join Date: May 2016
i had my ss lines and fluid done at a performance shop and it was way cheaper...
as for oil change and rear diff fluid change i had my dealer do it and they are good at that stuff lol brake backing plates i will do myself and its super easy about 1-2 hours total
Andrew Bettridge
Account Manager Extreme Dimensions 1-714-278-8000 EXT 17 andrew.bettridge@extremedimensions.com |
Thanks.
I did my steel braided brake lines today and the backing plates - myself and a friend. I should have flushed the fluid, but I need to burnish the pads, so I thought I would do that, then flush to DOT4. So the dealer will get the diff flush, A8 track fluid inspection and possibly the DOT 4 flush. Thinking that should be $200, since I'm supplying the brake fluid.
Mike Dee
#7 |
![]() Drives: 2016 Camaro 2SS Join Date: Oct 2013
Diff fluid change on this car is awfully quick/easy, fluid, additive, 3/8" ratchet (no socket needed) a small pump (like $8 on Amazon). Takes about 15-20 mins and most of that time is letting it drain. Don't even need to jack up the rear. I did it both before and after my first track event since I had 10k miles on it before my first event.
Easier/cheaper than an oil change. I did everything but the tranny check myself, the brake ducts/plates were by far the worst, solely due to the torque required on the caliper bolts. |
