Old 05-23-2017, 09:24 PM   #1
1LE caSSper
1LE caSSper's Avatar
Drives: White 1LE
Curiosity: why does this product exist
I've seen this and pondered about it, what differences could it make / help?
Https://www.jreperformanceparts.com/...elocation-kit/
Anyone know or heard of our car heat soaking and/or pulling timing losing power significantly in traffic, on track or summer heat?
All cars lose power somewhat but others benefit from relocating the sensor to cooler areas around the car. This applies greaty some mustangs and sportbikes I know dyno and suffer from bad sensor placement oem.
This necessary with ours here for 35$?
1LE caSSper is offline   Reply With Quote
Old 05-23-2017, 11:05 PM   #2
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
that is probably for a engine or intake swap were the factory harness doesnt reach the IAT on the new engine.
Old 05-23-2017, 11:30 PM   #3
slick3
Drives: Garnet Red - 20 ZLE
IF you relocate the IAT sensor, you can fool the computer into thinking its cooler than it is. IAT dictates timing advance and retard above and beyond certain limits. To hot and it will pull timing etc.
Its not needed, I had an e39 M5 were this used to do wonders... The OEM placement was horrible. Even at cruising with ambient 70 degree temps the IAT would be 110+. This care does not have that problem. Besides it can be modified in the tune.
slick3 is offline   Reply With Quote
Old 05-24-2017, 12:10 AM   #4
red70tvhs
Red
red70tvhs's Avatar
Drives: 2018 Mosaic Black 2ss M6
I have this done on my GTO. It would heatsoak horribly. Now I'm rarely above ambient unless I'm sitting extensively.
Stock. For now...
red70tvhs is offline   Reply With Quote
Old 05-24-2017, 05:41 AM   #5
PRAY
PRAY's Avatar
Drives: 2016 2SS
I run them on my centrifugal blower cars that have meth.
Old 05-24-2017, 08:12 AM   #6
TJay74
Seeing as the stock IAT is almost in the airbox I don't see this doing much at all.
