Old 05-22-2017, 09:17 AM   #1
SS2017
Drives: 2SS & GT Premium
Slight orange peel, any way to correct besides wet sanding?
My car has pretty decent paint, but there is some orange peel of course, especially on the hood and roof and trunk lid. On my Cayman I had the whole car wet sanded, but I really don't want to get into that again, and this cars not as bad.
So, is there any other way to make the orange peel less noticeable, like can a detailer use various cutting pads and such to smooth it out at all? Or is there nothing else but wet sanding?
Thanks all.
SS2017 is offline   Reply With Quote
Old 05-22-2017, 09:29 AM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
There are two pads sold by carpro , called a velvet and denim pad, used by pros, and takes a long time. Ask a detailer about this process.
Old 05-22-2017, 03:37 PM   #3
SS2017
So by your response I am guessing this would be just as costly as wet sanding?
I am thinking my anal self needs to just leave it...I mean it's not bad, I just wish it was perfect. But it isn't a $250,000 show car right?
Old 05-22-2017, 03:47 PM   #4
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Leave it alone...
Old 05-22-2017, 04:56 PM   #5
SS2017
Leave it alone...
I see you are very much into detailing, did you do anything about your factory orange peel or just leave it?
Old 05-22-2017, 07:26 PM   #6
pjz1082
pjz1082's Avatar
Drives: 2016 Camaro 1LT
Just curious, why do they call it orange peel? Does that term go back to older types of paint or something?
pjz1082 is offline   Reply With Quote
Old 05-22-2017, 07:27 PM   #7
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Have you ever looked closely at the skin of an orange?
Old 05-22-2017, 07:31 PM   #8
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
I wet sanded my vette, but I've been painting and detailing for 20 years., it takes two different polishing machine's, 3 diff polishes, 36 hours worth of work, and you better have done it before. It's not a job for the faint of heart, most detailers won't even attempt it.
Old 05-22-2017, 07:38 PM   #9
pjz1082
pjz1082's Avatar
Interesting. I still think that term is a stretch but ok. The peel part is what throws me. I'm thinking of the verb, not the noun
Old 05-22-2017, 07:44 PM   #10
Burly
Burly's Avatar
Was your Vette that bad that it needed it? My Camaro has orange peel look in some places but not bad enough, to me, worth fixing. Now the water spots drive me insane!
Burly is offline   Reply With Quote
Old 05-22-2017, 07:46 PM   #11
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
The 14 c7's were terrible.....esp the vertical surfaces, and exactly why Bowling Green is putting in all new paint facility/line that comes on stream next year. This is the 14 Vet, it is on the extreme end, but many are just as bad as this. My Camaro is acceptable, no need for wet sanding.
Old 05-22-2017, 08:01 PM   #12
Burly
Burly's Avatar
Wow, that is bad.
Old 05-22-2017, 08:42 PM   #13
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Every car made has some orange peel, unless you buy a Rolls Royce. Unless your planning on only taking the car to shows, removing the orange peel on factory paint isn't a great idea.
Most modern cars have about 50 microns of clear coat on them. This is about the same thickness as the cellophane cigarette packs are wrapped in. It's also possible that the base coat has some orange peel as well.
Orange peel is caused by hills and valleys in the paint. So in order to remove it, all the hills have to be leveled to the valleys. This could mean removing 50% or more of the clear coat that is on your car.
Doing this brings lots of bad things possible afterwards if your car is driven.
Any bird bombs or bug etchings can go though the paint much easier now since it's so thin.
UV rays from the sun can cause premature clear coat failure due to it being thin.
Aggressive compounding can't be done if needed for a scratch if you happen to get one.
Save the money for the job and use it for a mod that you will enjoy on your car!
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 05-23-2017, 11:47 AM   #14
timmy8784
Drippin' Wet Auto Detail
timmy8784's Avatar
+1 on this. The benefits do not out weigh the cons. Once you start noticing orange peel, you will see it on EVERY car. Unfortunately something that we just kinda need to accept unless you wanna take the risks and put in a crazy amount of time.
timmy8784 is offline   Reply With Quote
