05-21-2017, 06:36 PM | #1 |
Drives: 2015 Chevy Camaro 1SS Join Date: Jun 2016
is a 700whp BTR stage 3 NA cam,whipple e85 possible?
I currently have a BTR stage 3 NA cam, ATI 10% underdrive pulley and supporting top end for the cam. I'm making 470hp and 432tq. Im looking at taking the next step in adding power and adding some boost to my life. I know my stock ZL1 pump that was put into the 14-15 SS can't handle much more than 650. Can i make 700 with the cam I have now with a whipple and E85 flex fuel? What size injectors do you guys recommend for this and what fuel pump? Should I swap out the BTR NA cam for a BTR stage 3 blower cam? Any advice would be awesome!
05-21-2017, 06:47 PM | #2 | |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
05-22-2017, 06:16 AM | #3 |
Drives: 2019 Corvette ZR1 Join Date: May 2017
My auxiliary pump system would give you the overhead you need for fuel volume.
05-22-2017, 06:37 AM | #4 |
You will need to get rid of the 10% under drive pulley as well. This will lower the boost from the supercharger
05-22-2017, 07:15 AM | #5 |
I was looking at the AGP TT kit for awhile now But how would I mount the turbos in the engine bay?
05-22-2017, 07:19 AM | #6 |
05-22-2017, 08:49 AM | #7 |
Agp tt kits are bottom mount, if you want top mount you would have to do a different manufactor,
Cai intake and a few other mods😎
05-22-2017, 08:53 AM | #8 |
Drives: 2010 camaro ss Join Date: Jun 2010
Looks like that's the hellion TT kit not the agp TT kit
05-22-2017, 01:26 PM | #9 |
Drives: it changes Join Date: Nov 2010
05-22-2017, 01:29 PM | #10 |
Answer
The answer is yes.
You need a big time dual pump fuel system and 1300 cc injectors minimum. |
05-22-2017, 03:05 PM | #11 |
not true as far as injectors go. I made 730whp with 1000s. could have raised base pressure and made more on them.
05-22-2017, 03:09 PM | #12 |
05-22-2017, 03:12 PM | #13 |
05-22-2017, 04:35 PM | #14 |
Fyi Heat management(turbo blankets/wrap ect.) is critical for any turbo system that places the turbos in the engine bay.
