Old 05-18-2017, 01:16 PM   #1
nate.the.great
Drives: 2017 Camaro 1SS 1LE
Any other folks with such a poor factory alignment?
Just wanted to see if anyone else discovered such a poor alignment from the factory and give other owners a heads up they might want to get theirs checked out.
nate.the.great is offline   Reply With Quote
Old 05-18-2017, 01:27 PM   #2
WillR
Drives: 2017 Hyper Blue ZL1
My Z has a slight alignment issue. The wheel is just so slightly turned. Need to get it checked, but haven't had time.
Current: 2017 Jeep Cherokee SRT
Previous:
2017 Hyper Blue ZL1
2013 IOM ZL1
2010 IOM 2SS
2000 NBM SS
1998 AW Z28
WillR is offline   Reply With Quote
Old 05-18-2017, 01:43 PM   #3
Paully104
Novice Driver
Paully104's Avatar
Drives: 2016 2SS Silver
Ruined my stock tires due to how poor the alignment was.
Modifications: BMR suspension & front brace, DSC v2 controller, ported throttle body, Rotofab intake, Rimblades rim protection (red)
Paully104 is offline   Reply With Quote
Old 05-19-2017, 12:13 AM   #4
2SSHIFT
2SSHIFT's Avatar
Drives: 2016 Hyper Blue Camaro 2SS 6MT
Thanks for the heads-up. I will have to get this checked out.
2SSHIFT is offline   Reply With Quote
Old 05-19-2017, 12:21 AM   #5
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Definitely check yours people. My factory toe was TERRIBLE!
Left front: -1/16
Right front: 9/32 (that's 3x out of spec)
Total front: 7/32
Left rear: 1/32
Right rear: 5/32
Total rear: 5/32
It doesn't get much worse than that.
Eric SS is offline   Reply With Quote
Old 05-19-2017, 08:44 PM   #6
DougCBJ
Drives: 2016 Blue 2SS
is this something you would take it to the dealership for? in order to drive straight i have to have the steering will slightly to the right, but it's not super bad.
DougCBJ is offline   Reply With Quote
Old 05-19-2017, 10:26 PM   #7
Stex
Drives: 67 goat, 69 goat ram air III
Yep, not just Camaro. Check any new car/truck esp. GM.
Stex is offline   Reply With Quote
Old 05-20-2017, 12:34 PM   #8
pete1077
Drives: 2016 Mosaic Black 2SS
My steering wheel was slightly off center from the factory. I had the dealer do an alignment a few months ago but it's still not straight. Nothing drastic but still not what you expect from a new car. I'll probably have them do another alignment.
Current 2016 Mosaic black 2SS.
Previous 1994 and 2000 Z28 sold.
pete1077 is offline   Reply With Quote
Old 05-21-2017, 08:31 AM   #9
Stex
Find a good independent shop to do the alignment properly. The steering wheel will be straight if they have a clue about what they are doing.
Old 05-21-2017, 10:10 AM   #10
thinkingcamaro
Drives: 2017 Summit White Camaro 2SS
Same issue...mine pulls to the left so I'm taking it to the Goodyear down the street that did my previous cars' alignments. Good (or bad?) to know I'm not the only one.
thinkingcamaro is offline   Reply With Quote
Old 05-21-2017, 01:32 PM   #11
thinkingcamaro
Results of my alignment. Plus bonus thread re: brake fluid and wheel!
Old 05-22-2017, 01:21 PM   #12
ponch333
Drives: 2017 Camaro 2.0 A8
Had to have three of my four tires replaced with less than 300 miles due to noise and vibration. The road force balance was off.
Why they did not replace the fourth tire is beyond me. It is odd. Also my A8 trans acts up intermittently. It' will shudder and then not downshift at a stop, then slip cuz its stuck in 3rd gear.
My point is with everything I see on this forum and the issues I have had it seems quality control at GM is lacking. That is all
just venting.
ponch333 is offline   Reply With Quote
Old 05-24-2017, 10:48 PM   #13
MasterTech
MasterTech's Avatar
Drives: 2018 1SS 6Spd
The factory only sets the car up roughly. It's the dealers responsibility to do a alignment during the PDI. That being said it almost never gets done. I have had to align my STI, 2 Dodge Rams and my HD2500. The Camaro will be very soon.
2018 SS
6 SPEED
NIGHTFALL GRAY METALLIC
MasterTech is offline   Reply With Quote
Old 05-25-2017, 10:09 AM   #14
Sftshldr
Beast Rider
Sftshldr's Avatar
Drives: 2017 ZL1 BLK A10
Before signing the papers on my ZL1 I had the service dept check the alignment. From the factory it was set in "Track" alignment per the tech. They asked if they should leave it there or did I want the "normal" street alignment. I chose the street. The "Track" alignment would have severely worn my tires I was told. The fronts might have lasted about 3000 miles before the wear patterns would have made them unusable. The back settings weren't very different from the street, but still would have caused higher wear on the tires.
Just my experience with the new car delivery from the factory at the dealership. Your experiences may differ.
"Just looking fast is sometimes all it takes!!!"
Sftshldr is offline   Reply With Quote
