Old 05-17-2017, 06:03 PM   #1
DevBlackSS
DevBlackSS's Avatar
Drives: 2016 Camaro 2SS M6
Royal Purple Synchromax
Has anyone used this stuff in in the TR6060 ? ive been searching but Im usually seeing the redline or amsoil brand being used. I used it in my t56 and it really felt nice. A little notchyness isnt a bad thing, but the way it feels stock fluid imo is just horrid.
Any info is appreciated!
715whp/665tq
DevBlackSS is offline   Reply With Quote
Old 05-18-2017, 09:23 AM   #2
TJay74
At 1500 miles I went from OEM to RP MAX ATF, it was a lot better. Then at 3000 miles I went to RP Syncromax and has been even better than the MAX ATF.
I would suggest it, it will make the world of difference in shifting in the TR6060
Old 05-19-2017, 11:32 PM   #3
DevBlackSS
DevBlackSS's Avatar
Great news! Im gonna throw some in tomorrow afternoon and test it out!
4 quarts if im not mistaken?
715whp/665tq
Old 05-31-2017, 10:12 AM   #4
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Yes I was thinking I'd read maybe 4.2 quarts. Here's a nice write up as well on "how to". http://www.camaro6.com/forums/showthread.php?t=492814
Ventmaster is offline   Reply With Quote
Old 06-08-2017, 11:36 AM   #5
exxit
Drives: 2016 1SS D1SC Methfed Lowered Wrapd
I noticed another thread about how someone described that the synthetic stuff MAY not be good for our 5th and 6th gears? My memory of it is cloudy and I don't remember the exact context but it was about synthetic transmission fluid vs manufacturer recommended.
Is there actually a debate about this?
exxit is offline   Reply With Quote
Old 06-08-2017, 12:25 PM   #6
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
The service manual says the MM6 (TR6060) takes Manual Transmission Fluid (88861800), which is basically Dexron III. The M13 (TR3160?....Non V8 cars) states to use Dexron VI. GM also states that Dexron VI is an approved replacement for Dexron III applications. I have used 88861800, Dexron III, and Dexron VI and have found aftermarket fluids to perform better in every case. I am using Redline D4 in both my 2010 and my 2016 and it's perfect. I am also a fan of my friends CTS-V that he runs RP Syncromaxx. I have changed another friends 2016 manual over to Syncromaxx as well, and it works great. IMHO, those are the only 2 fluids that make these trans shift perfectly. I have over 130K on the 2010 and about 7K on the 2016. Myself and all my friends track their cars with these fluids and have had no issues at all. Redline D4 or RP Syncromaxx, you won't regret it.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 06-30-2017, 03:11 PM   #7
SSDanny
Drives: 2017 Camaro SS M6
I just put in RP Synchromax into my transmission yesterday, and all I can say it's the best thing I've done to my car yet. The shifts are more effortless and don't make that awful noise when you throw it into the lower gears. I believe it was 3.65 quartz according to other forum members, so that's what I went with.
SSDanny is offline   Reply With Quote
Old 07-06-2017, 02:39 PM   #8
crankaholic
crankaholic's Avatar
I did a full trans and diff flush with RP synchromax and 75w90 gear oil respectively. I just drove it home from the shop, but I already noticed the smoother gear changes The diff is obviously not something you can feel, but I want to take care of my baby.
Do I feel like it's worth flushing your transmission fluid ahead of time? I think so... it's not a drastic change when shifting at higher RPMs, but it's a pretty significant change in terms of shift feel at normal speeds. I'll obviously have to drive the car some more as it's raining and I didn't get to do a lot of high RPM shifting.
TL;DR - gear selection is noticeably smoother and I'm happy with doing a flush ahead of schedule.
crankaholic is offline   Reply With Quote
Old 07-06-2017, 04:40 PM   #9
somewhatdamaged
somewhatdamaged's Avatar
Drives: 16' 2SS M6
I've tried both Royal Purple and Redline - prefer the Redline - really smooth shifts, even when cold
somewhatdamaged is offline   Reply With Quote
Old 07-10-2017, 01:13 AM   #10
Henkle
Henkle's Avatar
Drives: 2017 50th SS Coupe M6
somewhatdamaged, which Redline fluid did you use?
I generally like Redline fluids better too; but I'd like to know other's experience as well.
Henkle is offline   Reply With Quote
Old 07-10-2017, 02:23 PM   #11
somewhatdamaged
Drives: 16' 2SS M6
D4 ATF I bought from Amazon, one gallon jug and use a fluid pump. Worked perfect and best value versus the individual quart bottles.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 07-10-2017, 09:30 PM   #12
Henkle
Henkle's Avatar
Thanks for the info, somewhatdamaged!
I'll try the Redline after my break-in!
Old 07-14-2017, 09:13 PM   #13
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Anyone try this stuff for their MN6?
BG is supposed to be top notch material,
https://www.bgprod.com/catalog/drive.../#bg-product-1
https://www.bgprod.com/catalog/drive.../#bg-product-7
Old 08-14-2017, 12:04 PM   #14
sschons74
sschons74's Avatar
Drives: 16 Camaro 1SS & 82 Silverado C10
Thanks for the advice. I changed mine this weekend to Redline and the shifts feel very smooth & luby now. I swear it even feels like I'm turning a few less RPMs for same speed, like 2100 in 5th for 60 mph. I ordered gallon from Amazon per your link and it delivered next day, awesome!
I took a few minutes to jack under tranny and remove X-brace, I still spilled it beyond drain pan, typical tranny drain for me, always a mess, but worth it.
Ordered 1SS Black on Black, M6 in late summer 2015.
Hurst shifter, Soler Performance ported TB.
sschons74 is offline   Reply With Quote
