![]() ![]() Drives: 2016/SS Has had 4 Gen 5's Join Date: Dec 2015
Gear indicator on DIC> Question?
Every so often I'll look down in the DIC and the light showing the GEAR I'm in will go from WHITE to Off Yellow? WHY?????? I have know Idea<<<<
SnoWhite |
![]() Drives: 2014 LS Join Date: Nov 2016
The indicator changes color if you have rev match on. Are you on an M6 using that?
Sent from my SM-N920P using Tapatalk |
AHHHHHHHHHHHHHHH yep that's what it is
so many things I haven't figured out in this DASH. I still can't find this 0-60 thingy<<<<I'm ashamed to say MY DIC is in the same display it was when I brought the car home a year ago :( I'm afraid I'll get some place and not be able to get back to where I started :((((((
SnoWhite |
![]() Drives: 2017 2SS Summit White Camaro M6 Join Date: Mar 2012
Maybe you should read the manual!
#5 | |
![]() Drives: None Join Date: Nov 2016
You have to enable the 0-60 timer. It is off from the factory.
-Brian
Hyper Blue 1SS / 1LE |
SoCal Mayhem
Drives: 2017 2LT Hyper Blue Metallic Camaro Join Date: May 2009
Use the controls on the right side of the steering wheel. Press left to bring up the menus you can change, then down to cycle through them, the middle button to select it. Once in those individual menus, you can press down or up to cycle through the options for that particular menu.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
The 0-60 timer and the other timers are in the Performance menu of the DIC. As said you have to go in thru the DIC user settings and turn on the performance timers and then you can access them.
#8 | |
![]() Drives: 2016 2SS, 2018 ZL1 A10 (RIPx2) Join Date: Jun 2016
Just take 20 minutes in the driveway some time, hold down the start button for 8 seconds or whatever to turn the power on without starting the car, and play with the menu/settings. Every time you see a < > ^ v next to whatever is central in the display, it's telling you that you can use a directional button on the steering wheel to navigate in that direction with the menu. It's pretty intuitive. You'll get it down in no time. |
