Old 05-12-2017, 09:18 PM   #1
NightfallZL1
NightfallZL1's Avatar
Drives: 2017 nightfall zl1
Going drag racing tonight what launch setup is best
Going racing and I am using the stock tires what rpm should I use. The track is good not great. Also it's a a10 car
NightfallZL1 is offline   Reply With Quote
Old 05-12-2017, 09:23 PM   #2
96MrBass
96MrBass's Avatar
Drives: GM
I believe someone said that they had decent passes with tour mode.
Roto- Fab Cai, SLP 1 3/4" headers, 3"X pipe, LM2 cat back, Comp Cam & AI Heads, SLP UP, RPM Tuned, GPI Intake, Vmax TB, ADM Air Scoop, 3.91 Gears, Gforce driveshaft, Braille 21#, Elite Catch Can, Pfadt Tie Rods, Diff Bushings and Trailing arms, Eibach spings & sways, BMR cradle bushings, Nt555r's.
96MrBass is offline   Reply With Quote
Old 05-13-2017, 08:37 AM   #3
ZL*Won
ZL*Won's Avatar
Drives: 2017 Hyper Blue Metallic ZL1 A10
Comparing best 1/4 time with Tour mode vs Track mode would be very interesting. Also with and without the traction nanny. Anybody done this?
2017 ZL1 Hyper Blue A10
ZL*Won is offline   Reply With Quote
Old 05-13-2017, 09:32 AM   #4
Artos
Artos's Avatar
Drives: A10 LT4
Can't you adjust the engine to track & suspension to tour from the screen??
I recall a vid of hellcat getting its fastest time when they were making several passes with this set up.
Artos is offline   Reply With Quote
Old 05-13-2017, 10:16 AM   #5
96MrBass
96MrBass's Avatar
Drives: GM
Did you make it out? Results?
Old 05-13-2017, 10:32 AM   #6
IneedAZ
IneedAZ's Avatar
Good question?
Old 05-13-2017, 10:39 AM   #7
Dethsupp0rt
Drives: None
Curious about this too.
I know there are 4 driving modes, but in a video I was watching I saw you could adjust some parameters from the screen.
This led me to believe you could adjust steering/suspension/throttle/trans (if A10) response independently.
Ideally, you would want the suspension in the softest mode ("Tour" on this car?) to get a better launch, and engine/trans in "Track" for drag racing.
Edit: Looks like you can, from this:
It also gave me some insight on another thread I started.
Dethsupp0rt is offline   Reply With Quote
Old 05-13-2017, 12:07 PM   #8
Zl1steve
Drives: Zl1
You can. When I ran my 11.20 I was in tour mode. Traction control off and had exhaust in track mode. And i shifted it at 6400
Zl1steve is offline   Reply With Quote
Old 05-13-2017, 12:24 PM   #9
IneedAZ
IneedAZ's Avatar
Are you going to try comparing your shifting vs letting it shift by itself?
Old 05-13-2017, 01:04 PM   #10
396ssrat
Drives: 66 Chevelle SS
You will be hard pressed to hook up with a stock type tire. Save the tires, buy some extra wheels and sticky tires, you'll be money and frustration ahead.
66 Chevelle SS 396
91 octane Driver n/a
6.44@105.78 1/8th mile
Old 05-13-2017, 01:21 PM   #11
Artos
Artos's Avatar
Drives: A10 LT4
I thought so too...when I first got it, I remember playing with the screen & putting steering & suspension in tour while keeping the engine/exhaust in sport or track. Made for good in town driving & think I'll start using this feature again.
I simply just moved to pushing the button for some reason...never thought about the versatility for the strip till now.
Old 05-13-2017, 01:22 PM   #12
ZL*Won
ZL*Won's Avatar
Your 11.2 was with stock tires? I assume you heated em up a bit first....
Old 05-13-2017, 04:11 PM   #13
Zl1steve
Drives: Zl1
Stock tires and I cooked them real good. They get nice and soft when heated up.
Old 05-14-2017, 12:14 AM   #14
Shorty45
Shorty45's Avatar
Drives: 2017 Summit White ZL1, M6
Launch question
Some of the questions you guys are having have been discussed over here in the 1/4m drag race and launch threads, here: there's some PDR stuff too. I also have found stuff in the Vette forum. Good luck.
http://www.camaro6.com/forums/forumdisplay.php?f=256
2011 Dodge Ram 1500 Longhorn Laramie
1966 Chevelle SS 396
Shorty45 is offline   Reply With Quote
