Drives: 2016 Camaro SS Join Date: Oct 2016
Starting N20 project
So after much debate I've finally settled on the path I'm going to take with my personal car. I have nothing against FI or H/C at all but I want a setup that will work well whether I'm on the street or at the track. My car is FBO and to be honest on a street tire 1st gear is useless and 2nd is hit or miss. So the plan is...
- retain FBO setup for 99% of the time I don't need more TQ/HP - have PRAY port the MSD - get the MSD plumbed for direct port - install dual bottle setup - install separate 1 gallon fuel cell for E85 with aux pump (may run race grade E85 here) With this setup there is no reason to enhance the factory fuel system. I can run full E85 off and on the spray and not worry about fuel pressure or injector window issues. And the intake valves will get a cleaning here and there ![]() I will try and do this in a way I do everything else... clean and well thought out. If I can achieve the system I want I will probably market it as a complete package. I'm also going to test out some things to see if I can get the ECM to pull timing automatically when the system is engaged without having to swap tunes in and out. Comments/thoughts are welcome. Tim |
![]() Drives: 2016 Black 1SS Camaro Join Date: Jul 2012
2016 Camaro 1SS M6 with MRC and NPP.
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” Albert Einstein |
![]() ![]() ![]() Drives: 2018 ZL1 Join Date: Oct 2011
Should make for a fun setup. Be sure to post pictures
2018 ZL1…Many mods to come
SNSTRSS
Looking forward to it!
2016 Black Camaro 2SS A8 NP
![]() Drives: 2016 NFG SS A8 Join Date: Jul 2014
If you and make it, it will no doubt be a high selling kit. Everything you do is top notch.
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
Thanks. My goal is to make it as plug and play as possible with the key safety measures in place. Cheap and dirty is not the right way to do nitrous.
#7 |
![]() Drives: '17 SS/1LE/PDR Join Date: Feb 2017
looking forward to this build!
PRAY ported MSD/TB : ROTOFAB/dry : DSX flex fuel : HPA Stage 3 : ARH catted long system/oem NPP : RSR harness bar : RSD : FSO1 : MPS4S 305F/325R
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
Still gonna be slow. LOL.
#9 |
SNSTRSS
Any progress with the nitrous build?
#10 |
Wanting to see how this turns out..
Sub
DMS Flex Fuel-E85
HPTuners Ngauge Roto Fab CAI, LPE Ported/Polished 95mm LT5Throttle Body, PRAY Ported MSD Intake Manifold, SP Coated TSP 1 7/8" Catlless Longtubes Hooker BlackHeart Cat-Back, Mishimoto Catch Can (Which always has some nasty in it )Instagram@Weapon_6 |
#11 |
![]() Drives: 2016 Camaro 2SS M6 Join Date: Mar 2017
This is going to be Sweet! Keep us updated!
715whp/665tq
#12 |
![]() Drives: 2016 Chevy Camaro Join Date: Jun 2016
Here's a universal tank from Nitrous Express. The pump, regulator, and plumbing retail for another 500-600 bucks to complete a standalone fuel system. So roughly $1000 bucks for that, then there's the question of how you deliver the nitrous by either a window switch or a progressive system. A progressive system would be alot better but wheel hop could still be an issue. So a one piece drive shaft and upper and lower control arms should be a high concern. A full hit on a window switch , its 50/50 on just how much the stock stuff will absorb. Then there's the AFM lifters. As I'm told , they seem to not like anything above a 175hp shot of nitrous. Im yet to 100% verify this however....
#13 | |
![]() ![]() Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
Ported intake manifold and throttle body kooks 2" headers no cats
#14 |
![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Nov 2011
Who Dares...Wins |
