Old 05-11-2017, 08:07 PM   #1
MAGAUSA
MAGAUSA's Avatar
Drives: 2017 Hyper Blue 1LE
How to remove sound tube? Just yank the crap?
What a PItA to get it disconnected from the firewall
MAGAUSA is offline   Reply With Quote
Old 05-11-2017, 08:24 PM   #2
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
No it has to be rotated. Remove the 10mm nut and rotate it clockwise.
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 05-11-2017, 08:41 PM   #3
MAGAUSA
MAGAUSA's Avatar
God bless you. Thanks.
Old 05-13-2017, 03:08 AM   #4
1LE caSSper
1LE caSSper's Avatar
Drives: White 1LE
Isnt there an open hose connection on the intake tube? What's the solution ????
1LE caSSper is offline   Reply With Quote
Old 05-13-2017, 08:20 AM   #5
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
If I can find the thread again, someone took an inverted 5/8 rubber plug and silicone it in
Post 26. http://www.camaro6.com/forums/showth...nd+tube&page=2
Posts 3,11,13 are useful too. http://www.camaro6.com/forums/showth...ght=sound+tube
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 05-13-2017, 02:29 PM   #6
MAGAUSA
MAGAUSA's Avatar
I did roto-fab, more so to presently make more room for a catch can by the TB. Longer term I plan headers, likely e85 and maybe more, figured the roto-fab may slightly help down the road.
Old 05-13-2017, 04:45 PM   #7
1LE caSSper
Drives: White 1LE
Might try this thank you!
