View Poll Results: Did you get a Check Engine Light after removing Secondary Cats?
Yes 5 7.25%
No 64 92.75%
Voters: 69. You may not vote on this poll
Old 05-11-2017, 04:21 PM   #1
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Does Secondary Cat Delete Increase Pops? Cause CEL?
Those of you with secondary cat deletes does the car seem to pop and crackle more on the over run? I'm looking to remove mine tomorrow.
Also have you guys had issues getting the welds done right to prevent the Check Engine Light?
Old 05-11-2017, 04:55 PM   #2
Hagels316
Drives: 2016 Camaro 2SS A8
before I put LTs on and a catback I drove around for about a month or so with the 2nd cats removed (welded straight pipes). No CEL at all and yes there were more noticeable pops and crackles (louder too).
Hagels316 is offline   Reply With Quote
Old 05-11-2017, 05:28 PM   #3
pinoyscorpion951
pinoyscorpion951's Avatar
Drives: 2016 Bright Yellow 2SS A8
Yup, before I was running headers with high flows, I had the secondary cat deletes and there was a noticeable increase in the pops and gurgles on deceleration.
pinoyscorpion951 is offline   Reply With Quote
Old 05-11-2017, 09:30 PM   #4
TJay74
Yep, same here.
Old 05-12-2017, 01:10 AM   #5
exxit
Drives: 2016 1SS D1SC Methfed Lowered Wrapd
Also, pull the fuse bruv. The NPP closes itself on decel. Much more noticeable when you have both cats deleted (because the puny valves rattle like crazy)
exxit is offline   Reply With Quote
Old 05-12-2017, 08:35 AM   #6
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I love hearing the overrun pops and bangs. I'm pumped to hear it even more.
FYI
Added a poll. Those of you who had this done please vote on if you did or didn't have Check Engine Light issues afterwards.
Old 05-12-2017, 08:54 AM   #7
FlashBang23
FlashBang23's Avatar
Drives: 2017 1LE
In for results......my last car (15 5.0 with roush axleback and x pipe) was crazy loud and made tons of pops and gurgles on decel. That is the one thing I do miss from that car on my 1LE. Hoped that the Borla S Type with x pipe would fix things but it isn't quite agressive enough for me.
17 Summit White SS 1LE PDR / Borla S type Catback / XPEL Ultimate PPF
FlashBang23 is offline   Reply With Quote
Old 05-12-2017, 09:01 AM   #8
FlashBang23
Drives: 2017 1LE
It closes itself even in track mode?
Old 05-12-2017, 09:13 AM   #9
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Yep, at part throttle and cruising too.
Old 05-12-2017, 09:19 AM   #10
FlashBang23
Drives: 2017 1LE
Cool, i knew it did cruising but did not realize it closed it on decel. Fuse will be out before I leave work for lunch today lol.
Old 05-12-2017, 09:30 AM   #11
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Fuse 51.
Old 05-12-2017, 10:29 AM   #12
Mighunter
Drives: 2017 Summit White 2SS
Not to hijack this thread, but I'm looking to upgrade to the borla s-type cat back. I keep reading on these forums that the exhaust is "welded" but when I read borla's instructions, there is no welding just clamps. Am I missing something?
Does this have to be done by a muffler shop or can i do this myself?
Mighunter is offline   Reply With Quote
Old 05-12-2017, 02:48 PM   #13
Hagels316
I think borla offers 2 versions of the catback. One keeps the secondary cats in place the other does not. The latter (no 2nd cats) does not require any welding, it should bolt right up to the factory primary cats. Keeping the secondary cats in place will require cuts and welds.
Just make sure you order the correct one.
Old 05-12-2017, 03:16 PM   #14
Mighunter
I was looking at 60610. ok so I see the 60609 removes the secondary cats. So no welding with the 60610.
Thanks!!
