![]() Drives: Camaro SS Join Date: May 2016
is it ok to use 100 octane? And will it give me any performance boost?
going to the track manana - they have 91 and 100 octane available. Any reason to try 100?
no boost AT ALL, not without a tune. but better than crappy 93.
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
Yes you can try it. I noticed I could not eliminate knock with 89. I only have 87, 89, and 93 around here. I also tried mixing 89 with half 93 to make 91 and it still knocked.
So you may be having knock if the max octane you can get besides 100 is 91. In that case you should experience a very small performance increase with 100, if you don't' already have knock then you wont see any gains. Knock is dependent on a lot of other things as well too though. |
![]() Drives: 2023 BMW M4 Competition Join Date: Dec 2012
Wont hurt anything. Your car will run more optimal on 100 octane if the available 91 octane is crappy quality.
2023 BMW M4 Competition (daily)
2022 ZLE M6 (weekend toy) 2022 BMW X3m40i Past: 2022 Tesla S Plaid 2020 Shelby GT500 sold 2019 Hellcat Redeye-traded for new GT500 2019 ZL1 A10 - sold (meh) 2019 Tesla M3P 2016 Hellcat Challenger - A8 sold but never forgotten 2016 Camaro 2SS M6 2014 Mustang GT A6 2012 Mustang GT M6 "brembo" 3.73/FBO 2012 Camaro SS L99 (Wife's)- slow |
![]() Drives: '16 2SS, '14 Z71 Join Date: Sep 2016
Higher octane does not help if it's not needed. It will not hurt your car at all as long as it is unleaded. In all reality, if it did anything noticeable it would slow your car down(compared to a good 93). However, if you have a good 91-93 just run that. Save the money as you will not be faster with it for sure. If your only choice it 87-89 or 100 and you are going to the track, grab the 100 for sure.
And Yes saying going from 93 to 100 will slow you down is an exaggeration. However it WOULD slow you down before it sped you up if 93 was enough for your car.
'16 2SS M6 & '14 Z71
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
If you saw any benefit it would only tell you that your normally used 91, 92 or 93 is crappy. Unless someone slipped a 100 octane map onto your ECU.
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
#7 |
![]() Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
Don't waste Your Money!!!!!!!!!!!!!!!!!!
#8 |
![]() Drives: 16 2SS Join Date: Feb 2017
Power density goes down slighly as octance goes up. You will make the most power with the lowest octane that does not cause knock. That said we are talking imperceivable differences.
2016 2SS, A8, Whipple 3.25 pulley, Mishimoto catch can, C7 Carbon fiber splitter and skirts, GM black brake and tail lights. PLX wideband O2/HP tuners. Apex VS-5RS in 19x11 and 19x12.
#9 |
![]() Drives: 2016 2SS, 2018 ZL1 A10 (RIPx2) Join Date: Jun 2016
The Gen-V LT1 is tuned for 93 octane. Running a higher aggregate octane rating is a waste of money.
If you live in a place (like I do) where 93 isn't available at the pump, you can mix 4.25 gallons of 100 octane with the rest of the tank full of 91 to blend up a tank of 93. I do this on weekends when I plan on doing some spirited driving, and then daily drive it on 91 the rest of the week. |
#10 |
![]() ![]() ![]() Drives: 2021 Tesla Model 3 LR Join Date: May 2016
Why were you using 89 and mixing 89 with 93 to get it to 91? 93 is perfectly fine for the car and is the recommended gas.
#11 |
![]() ![]() Drives: 2014 2SS/RS 1LE Join Date: May 2013
We had a similar discussion in the 1LE section a few days ago, you should check it out. http://www.camaro6.com/forums/showthread.php?t=493850 As others have already said here there is no advantage to running 100 octane in a car designed/tuned for 91/93, its just a waste of money.
Even if the car was tuned for 100 octane exclusively you would not see much more than a few HP increase due to the fact that the engine is already designed to achieve peak cylinder pressure on 91/93 and you can't increase peak cylinder pressure without forced induction or changing cyl geometry. (to increase compression ratio) So save your money.
#12 |
#13 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
So with that OP, 4-6 gallons of 100 octane and the rest being 91 octane will get you to around 93, but I wouldn't run pure 100 octane as the higher the octane the slower the fuel burns as this is how it combats spark knock. So as said, higher octane fuels burns slower and could potentially produce less performance if it is not needed. |
#14 |
![]() ![]() ![]() Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
Unless you are simply trying to reduce the chance of knock, no it's a waste. At the race track (road course.) You could add a few gallons to raise the overal octane rating of your fuel and reduce the chance of detonation. No other logical reason to run it is coming to mind
