Old 05-09-2017, 10:56 AM   #1
koolisdon2006
koolisdon2006's Avatar
Drives: 2012 Camaro 2SS L99 Victory Red
New Camaro A8 Question
Does the new Auto have a rev limiter at idle? I had a auto 2013 Camaro a few years ago and it wouldn't let you rev past 4K or something like that. Thank you.
koolisdon2006 is offline   Reply With Quote
Old 05-09-2017, 11:18 AM   #2
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
I have the manual but yes it limits earlier in neutral. I think its either 5k or 5500.
marknagy13 is offline   Reply With Quote
Old 05-09-2017, 01:33 PM   #3
Hagels316
Drives: 2016 Camaro 2SS A8
its around 4k in either Park or neutral. I rev it all the time during car meets.
Hagels316 is offline   Reply With Quote
Old 05-09-2017, 06:09 PM   #4
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
I'm wondering what the point of this limiter is? I'm assuming is it will give the throttle angle enough of a buffer if someone did a neutral to drive drop rather than a neutral to drive drop at redline? Or maybe the 8L90 valve body is plumbed electronic to engage the drive circuit? I would think it would be mechanical from the shifter to engage drive for a limp mode?
Obviously revving your engine at redline in neutral has no good purpose haha, but yes there is a limiter in park and neutral at 4,400rpms or around there I think.
cmitchell17 is offline   Reply With Quote
Old 05-11-2017, 11:07 AM   #5
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
It's mainly to protect the car. Part of it is somewhat like you said to provide some protection to the trans/driveline. It's also to protect the engine itself. High RPMs without load isn't necessarily a good thing, and in certain circumstances has the potential to cause damage.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
