Old 05-08-2017, 08:13 PM   #1
Racereadyfab
Drives: 2017 Camaro 2SS
2017 Camaro 2SS Baseline dyno runs fresh from the dealership 101 miles
Might as well make the first post a good one. Picked up my 17' camaro today and since I conveniently have my shop located next to a dyno shop and I picked up the new car today I had no choice but to see what it's got completely stock untouched a couple hours after receiving the keys! Can't wait to start the bolt ons, e85 pulls coming soon once I put a kit together and will post results in stock trim.
2017 Camaro 2SS M6 100% stock at the moment
1.839 60' 12.113@114.95MPH 6/9/17
12.267@115MPH 5/17/17
12.374@116.83MPH 5/10/17
Racereadyfab is offline   Reply With Quote
Old 05-08-2017, 08:24 PM   #2
Racereadyfab
https://youtu.be/gnkLZ1mbFgA
Old 05-08-2017, 09:39 PM   #3
TJay74
Wow, that is a very generous dyno for sure. Dang near what the car is rated at from the factory at the wheels.
Old 05-08-2017, 09:42 PM   #4
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
I'm actually more curious to see what it dynos after a few thousand miles stock vs. new stock to see if the motors free up a few ponies after they get broken in.
Eric SS is offline   Reply With Quote
Old 05-08-2017, 09:59 PM   #5
DevBlackSS
DevBlackSS's Avatar
Drives: 2016 Camaro 2SS M6
Great looking car and numbers! I admire the white! Going to assume M6 right?
My car's baseline was 419/421. Congrats on the pick up!
Looking forward to your progress! Best of luck
715whp/665tq
DevBlackSS is offline   Reply With Quote
Old 05-08-2017, 10:10 PM   #6
Racereadyfab
Thanks! And Yes totally forgot to put that in there it is a M6 I'm excited to see the gains moving forward. Track times to come this Wednesday if we don't get rained out here in NH.
Old 05-09-2017, 01:35 AM   #7
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
I dont beleave it. these cars put down 390hp 400ftlbs stock
Old 05-09-2017, 08:30 AM   #8
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Happy Dyno...
Old 05-09-2017, 08:47 AM   #9
enzia35
Drives: '16 Garnet Red 1SS
Well it looks like the dyno is connected directly to the hubs, less drive train loss through the tires?
'16 Camaro 1SS
'18 Miata GT
Old 05-09-2017, 09:12 AM   #10
KMPrenger
KMPrenger's Avatar
Dyno results should never be gospel in my opinion, but if you can imagine the extra ponies every car would show on a typical dyno if you removed 30 pounds of wheel/tire weight (from each side) on the dyno....then this result likely wouldn't be far off, seeing as how this dyno hooks directly to the hubs.
The proof on this is in how a GT350R with the lighter wheels will dyno a bit higher than a regular GT350.
Old 05-09-2017, 10:26 AM   #11
Redlinez
Shifts under load
Redlinez's Avatar
I have your twin in a 1SS. I bet $$$$ mine puts down 385-395 when I finally go. I'm at 2500 miles. As long as you just keep going there, you'll get the right info out of your mods.
22 Suzuki GSX-S 1000GT blue
Old 05-09-2017, 12:34 PM   #12
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
those numbers seem very high
SSTony is offline   Reply With Quote
Old 05-09-2017, 02:00 PM   #13
Racereadyfab
The numbers are comparable to Dynojet numbers with how its setup to read everyone around this area compares numbers to dynojet (mostly mustang fans) and thats been tested back to back with multiple cars to calculate a dynojet figure. It is a land and sea hub dyno and its numbers were 395hp land and sea numbers.
As stated several times by a number of people across hundreds of dyno debates it is just a tool and the numbers are a good starting point for future mods to compare to and build off. These numbers will be backed up with track times and will actually be putting the car on another friends dynojet rollers to see how it compares(its nice to have friends with dynos) just out of curiosity. FYI the car was flowing 45lbs/min of air which roughly would equal 450hp then obviously figure drive train loss. All in all I am happy with the data and plan to build off of my numbers to know which parts gain what and constantly back up numbers at the track to have a more accurate sense of power the cars making.
Old 05-09-2017, 05:55 PM   #14
parbreak
Drives: 2017 50th Camaro SS
Mine put down 418/426 to the tires
parbreak is offline   Reply With Quote
