Old 05-06-2017, 11:56 AM   #1
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
RPM TB charge pipe and ZZP silicone intake tube installed.
Took a little over an hour, but the intake tube took literally 5 minutes. Charge pipe took longer since I was learning as I went. Still not too bad. It was fun and I think it cleans up the engine bay nicely.
Old 05-06-2017, 12:02 PM   #2
b0bsaget007
b0bsaget007's Avatar
Drives: 2016 2LT RS Blue Velvet
Lookin' good! Can't wait to see the results post tune!
PC: i5-6600; RX 480 4GB; 16GB DDR4; Samsung 950 PRO 512GB SSD
Car: 2016 Camaro 2LT RS 2.0T 6M Blue Velvet Metallic | ZZP Hi-Flow Catted Downpipe | Injen EVO7300 Cold Air Intake
b0bsaget007 is offline   Reply With Quote
Old 05-06-2017, 12:08 PM   #3
Michigan1LTRS
Blessed ❤️
I won't be doing a tune until when and if I start more involved mods. Downpipe and intercooler would be nice, but i can't do that myself. Have to find somebody who could do it. Then I would add a tune. These two mods were more about making things look good.
Old 05-06-2017, 01:11 PM   #4
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
Looks great in the engine bay. Nice work. What are your driving impressions with these upgrades? Don't doubt your ability to do the work yourself for the downpipe installation. The intercooler won't be that hard either.
Start The Machine is offline   Reply With Quote
Old 05-06-2017, 02:05 PM   #5
Michigan1LTRS
Blessed ❤️
Ok, just got back from a good drive. Turbo is a bit louder, but nothing that much. No CEL's, low end seems to pull harder. Didn't do any high speed runs. Biggest thing I noticed was the RPM charge pipe was just barely warm. If i remember correctly the stock plastic pipe got quite hot. Somebody please correct me if i am wrong. One thing I will say, please check your charge pipe for metal burrs. I had a pretty good size one on the inside where the sensor goes through. Not sure if it would have come off, but if it did and got sucked into the engine, well that's probably not gonna be pretty. Glad I saw it and removed it.
Old 05-09-2017, 02:59 PM   #6
Michigan1LTRS
Blessed ❤️
Ok, after putting some miles on since installing them I am very pleased. Fit and finish is fantastic. No movement at all. Two very fine products. Performance wise not sure much is there however in conjunction with other mods I'm sure they will be of benefit. I am going to try for some 0 to 60 times to see what she does.
Old 05-09-2017, 05:18 PM   #7
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
I believe the temperature differential you're feeling is due to the RPM pipe retaining the heat inside and under the coating, where a factory nylon tube better dissapates that heat. Nylon/plastic will always have better thermal dissapation properties than most metals.
ChicagoTommy is offline   Reply With Quote
Old 05-09-2017, 05:22 PM   #8
Adp2017
Adp2017's Avatar
Drives: 2017 RS Turbo
Looks good man! Installing parts is almost as fun as reaping the rewards!
2017 1LT | RS | 2.0T | M6
331 rwhp , 350 rwtq
ZZP Intercooler | ZZP Catted DP | Magnaflow Catback | Injen CAI | Tuned (BBR) | CNC Honed Turbo (TPC) w 14lb actuator
Adp2017 is offline   Reply With Quote
Old 05-09-2017, 05:25 PM   #9
Adp2017
Adp2017's Avatar
You should just go for it and try to install an intercooler yourself. Getting the fascia off will be the hard/annoying part but after that everything should be in and out easy... As far as I know, and at least hope. I orders the zzp intercooler and am just gunna go for it on my own, mind you I am not expert but enjoy a challenge
ChicagoT did you work on your ATSintercooler on your own?
331 rwhp , 350 rwtq
Old 05-09-2017, 05:38 PM   #10
Michigan1LTRS
Blessed ❤️
That's awesome man. I look forward to your install. Maybe it will inspire me.
Old 05-09-2017, 05:48 PM   #11
Michigan1LTRS
Blessed ❤️
Hmm, you make a valid point for discussion. I hope psykostevo from RPM chimes in here. Love to hear his take.
Old 05-09-2017, 06:25 PM   #12
ChicagoTommy
I didn't install the intercooler. The intercooler is on my buddies 2013 ATS, not my 2014. I usually try to point that out to help alleviate confusion. I don't believe the intercooler install is too terribly difficult. Michigan can do it himself, or, he is within driving distance of ZZP.....
Old 05-11-2017, 04:04 PM   #13
psykostevo
Drives: Smart
Agreed, Looks great!
psykostevo is offline   Reply With Quote
Old 05-11-2017, 04:08 PM   #14
psykostevo
Drives: Smart
Based on your initial comment that spurred his reply, it sounded like you were stating that the stock charge pipe used to get hot, and the RPM pipe was just warm?
We make the pipes out of metal because it's strong, and it's also MUCH cheaper to go into production than injection molded polyurethanes. The upfront cost of plastic injection molding is ridiculous.
