![]() Drives: 2016 nightfall grey 2LT V6 Camaro Join Date: Feb 2017
Removing interior pieces
Does anyone know how to remove the silver trim around/above the gauges? I hate the silver and want to wrap it. Thanks!
![]() Drives: 2017 Camaro 2SS, Black/Red Join Date: Mar 2017
Pull the dash trim (easy) and behind there are simple clips to remove the chrome. Pulling the dash trim is almost as simple as pulling the passenger side trim insert. There is a Lethal video showing start switch r & r that gives most of what you'll need to know. The rest is easy to figure out. They don't need forced, they pop off easy.
I pondered doing something with them as well, but they do match the a/c vents. Decided not to throw off the consistency. https://youtu.be/dYfkLRU6hJQ Last edited by Lemooreace; 05-05-2017 at 06:53 PM. |
#3 | |
Thanks!! I thought about the vents too but I just can't stand it. That and the silver on the bezel around shifter. Thinking carbon fiber or red |
#4 | |
I have two sets so I can play with one without worry. Let me know what you do and send photos. I need inspiration. |
I've got the red around my shifter. Going to go red above the gauges as well. Check out Rivercity Creations, they do a great job. Or you can spay them yourself. The shifter came from them but I did the gauge pod myself.
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear. |
Could you post a few pics of the center console with the red bezel from above?? Deciding on it
#7 |
Here's my mods. I'll only post a few here. I will do a solo post to thank the vendor that helped put this together for me.
#8 |
Will do, but it's going to be a few days.
#9 |
![]() Drives: 2016 Camaro 1LT Join Date: Apr 2016
Those air vents come out really easy, in case you were wondering. Might be a little hard to wrap but you could def paint them. Or dip them. I have dipped the shifter trim and gauge trim a couple times but haven't decided on a final color yet. Once I have i plan on spraying the air vents and steering wheel trim also. I personally hate the shiny look. Really wish GM offered some kind of color conversion kit for all of those pieces. Living in AZ, the sun blinds you when it catches certain angles.
#10 | |
#11 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Nice thread. Thanks!
#12 |
![]() Drives: 2014 Chevy Camaro 2LT RS Join Date: Jun 2011
Shifter bezel for automatic
I bought the custom painted shifter bezel from RPI and I am having problem taking stock center gear indicator to put in new bezel. Anyone know how to take it out of stock bezel. RPI have no instructions for install.
