Old 05-05-2017, 01:19 PM   #1
mbar
Drives: 2016 1SS
Rear stock 9.5" in the front
I have an opportunity to buy 4 rear 20X9.5 stock takeoffs for a funny price.
1. Did anybody try to put rears in the front with spacers ? Which size spacer?
2. Would you use this size spacers if you track your car?
Thanks
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
Old 05-05-2017, 01:41 PM   #2
Camaroguy555
Drives: SUMMIT WHITE 2016 1SS NPP 6MT MRC
I did this and it did require a 15mm spacer. I used an adapter though so it had new studs. With 15mm there was room for a 285/35r20 without any rubbing.
Camaroguy555 is offline   Reply With Quote
Old 05-05-2017, 02:01 PM   #3
Mountain
Mountain's Avatar
http://www.camaro6.com/forums/showthread.php?t=485916
Old 05-05-2017, 02:02 PM   #4
Mountain
Mountain's Avatar
Where were you rubbing that you required a 15mm spacer?
Old 05-05-2017, 02:34 PM   #5
mbar
Drives: 2016 1SS
Originally Posted by Mountain View Post
Thanks. I give up. Sounds like bad news
Old 05-05-2017, 08:07 PM   #6
Mountain
Mountain's Avatar
Originally Posted by cooper1965 View Post
It will hit the strut.
OK, but where exactly is this being seen? There are only two spots for interference: the strut-to-spindle bolt flanges and the spring seat. The bolt flange can be trimmed and, my measurements proved only a 5mm spacer being needed. I have to imagine with a 15mm spacer you have a LOT of extra room. If a 20x10 with a +25mm offset fits without any modifications, a 20x9.5 with a +34mm (5mm spacer) offset should (if ANYTHING, minor filing/trimming. The spring seat is dependent on the overall diameter tire you use.
