Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 05-04-2017, 10:58 AM   #1
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Z28 UCA bushings from GMparts direct - need clarification
So my order from GMpartsdirect direct finally arrived...after they said that one of the bushings was unavailable...and I requested in writing that the order be cancelled....and I now have this dilemma. I have researched the web and C5 trying to get clear pics of BOTH left and right bushings...I have read that both bushings are solid but all the pic's show the right is solid and the left has some voids...what gives...I have also read where GM will fulfill an order and sends out either a ZL1 or 1LE instead...so what do I have?Name:  z28 uca bush top.jpg
Name:  z28 uca bush side.jpg
I want to get these installed and hopefully get to the strip and see how my latest upgrades work in the Q.
TKS in advance!!!! peace out...
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 05-04-2017, 11:08 AM   #2
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I think Pete from JPSS will know the correct answer to this.
Try contacting him.
http://www.jpssonline.com/shop/z28-r...rm-bushing-set
Sent from my SM-G935V using Tapatalk
Firefighter is offline   Reply With Quote
Old 05-04-2017, 11:38 AM   #3
PostNup
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99
Yep - Pete hooked me up. Both of mine are solid, no voids.
Make sure you get this fixed before you put it on and you will be happy!!
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires.
PostNup is offline   Reply With Quote
Old 05-04-2017, 12:40 PM   #4
frankwjr
frankwjr's Avatar
That's what is was 'fraid of...dang-it!....wonderin if it's goin to be worth the f'kin headaches gettin this straighten out...tks...
Old 05-04-2017, 12:48 PM   #5
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Yea mine were both solid as well.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 05-04-2017, 07:13 PM   #6
ColdfuzionTN
Drives: 2012 Camaro SS
Same both solid, Give pete at JPSS a shout and I'm sure he can get you what you need super quick to.
ColdfuzionTN is offline   Reply With Quote
Old 05-05-2017, 08:09 AM   #7
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Agreed on all the above I got mine from Pete, there was issues of a right side being put in a left PN box or vice versa for awhile, haven't seen your issue. Pete can take a solid bushing an flip it around and restake the bushing so it fits right.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
