Old 05-04-2017, 03:22 AM   #1
fast4valve
@fast4vavlezl1@lt4_nation
fast4valve's Avatar
Drives: 2018 ZL1 1LE
295/30/20
Sorry in advance if this topic has been brought up before. Did a forum search with no luck
Ok...can we run a 295/30 up front without any clearance issues on a 10in wheel?
fast4valve is offline   Reply With Quote
Old 05-04-2017, 09:11 AM   #2
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
per the specs on the tire size, it should. stock 285/30/20 diameter 26.8", 295/30/20 27". Section width and tread width are real close too.
nancygrl is offline   Reply With Quote
Old 05-04-2017, 09:44 AM   #3
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
The 5th Gen could accommodate 1 size up both front and rear without any issues. 315 rear and 295 front is a common setup.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 05-04-2017, 07:13 PM   #4
fast4valve
fast4valve's Avatar
Thanks for the input. Just concerned if the tire would make contact with the strut or inner fender
