Old 05-03-2017, 06:33 PM   #1
mustangcrusher1
mustangcrusher1's Avatar
Drives: 2017 camaro SS blue w/white stripes
hp tuner will not connect the MPVI HELP
Ok i got past the 1st step with the usb stick install the next is to connect the MPVI and its not recognizing the MPVI. The green light goes on and when i plug the usb cable in the computer it makes the connection sound the computer makes and then nothing!!! A LITTLE HELP PLEASE!!!!
Im using windows 7
mustangcrusher1 is offline   Reply With Quote
Old 05-03-2017, 10:13 PM   #2
slick3
Drives: Garnet Red - 20 ZLE
plug it into your laptop and go into device management... so you see MPVI driver? if you dont the driver is likely not installed correctly. Look up how to manually install a driver for a device in windows 7 and follow the steps. It should take you 2 minutes. If you need more help, PM me or find your nearest IT buddy.
slick3 is offline   Reply With Quote
Old 05-04-2017, 06:41 AM   #3
mustangcrusher1
I went to my device manger and its not there... Im gonna try to figure this out this evening, I may PM you...Thanks
Old 05-05-2017, 06:12 AM   #4
mustangcrusher1
I had to down load a Net file, I never have done any updates on my computer, I had 192 updates waiting... now if it would just quite raining!!
