Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
Who has a fuel line disconnect tool that actually worked on our PCV connection?
AND where did you get it? I'm not buying intake or tube until I can get this off. Yes, I could break it, but i don't want to do that. OR is there another way it comes off without it breaking it. Thanks for the help fellas.
Kindness and compassion #OthersFirst |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
The line running to the intake is the only one that I could actually remove with the Mishimoto tools...took less than 5 min but had to detach the intake tube so I could access both clips...
Tried with the tube attached, but there was no way...(at least not for my fat hands)
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed |
Blessed ❤️
I know there was a post that said they got a fuel line disconnect tool to work, but i cant find it. Except for you CC, I think everyone else with a 2017 has broken theirs off.
![]() Drives: 2017 Chevrolet Camaro 2.0 LT Join Date: Apr 2017
I had a old set (Blue point) I got when working in a shop, and several of them would have worked. I believe I used the blue one, second from the smallest. But you can probably get individual disconnects at part stores. I just slid it up in there, and pulled the line straight back, no breaking maybe 5 seconds.
https://store.snapon.com/Fuel-Line-D...--P645405.aspx Last edited by Gutling; 05-03-2017 at 04:49 PM. |
#5 | |
Blessed ❤️
Sorry about that, I updated it.
And the actual clips that hold it on are right near the very edge. At first I thought my tools were too short, that they had to reach where you can see the indentions at. But they are actually right near the bottom of the plug. |
#7 | |
Blessed ❤️
#8 |
Blessed ❤️
Ok, I've got that colored set in the link you provided. So that should work?
#9 |
It worked for me lol. There was no click or anything once they were released, but once I got the tool slid up there a little bit I just pulled straight back and it came off with little pressure.
#10 | |
Blessed ❤️
#11 |
Lol glad you got it. Want to see pics/impressions when on!
#12 | |
#13 |
Blessed ❤️
Putting RPM charge pipe and ZZP silicone intake on Saturday. I'll post up the pics. So, for anyone who wants to know, this disconnect tool worked.
#14 |
![]() Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert Join Date: Feb 2019
Revisiting an old thread to Thank You guys (Gutling, Michigan1LTRS) for posting this! Followed what you did to remove the factory intake and replace with the ZZPerformance Silicone Intake Tube.
I used the exact same tool and it worked on my 2017 with the 'revised' clips. The instructions from ZZPerformance made it seem simple to remove the hose by hand. I'm usually impatient and was attempting to muscle it off with a screwdriver and trim tools. I took a step back, searched Camaro6, and landed on this thread! Glad I did it instead of breaking the clips as I'm still under warranty and will be swapping back to my factory tube when I take my car to the dealership for service. Thanks again
