Rev Limiter hits at 5k to 6k in first and second Gear 1600 mile mark
I have a 2017 ZL1 6speed Manual and I just hit 1600 miles and wanted to see how this thing pulls from first to second gear and the rev limiter is all over the map,sometimes it cuts the car off at 5100 rpm and at 6000 rpm.
When you down shift into second gear and floor it it will sometimes hit 6500 but will hesitate at 5100 rpm most of the time. Someone said something about a air filter problem?? Not really sure I believe that could be it but who knows. I race Super Stock Race cars and work on cars for a living so I do know how to test this car in all driving modes.Just starting to get into any info anyone has on this. I have tested in all driving modes it does the same thing it just cuts the car off at different rpm's. Didn't get to third gear yet..
DCosta9 |
Bring It
I have an M6 as well but haven't experienced the same yet. Subscribed for the info.
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 A10 Join Date: Nov 2008
Do a search, another guy is having the same problem, dont think there was a fix or the op didnt post the fix.
-bobby
ZL1::J-E-T-S JETS JETS JETS |
Yeah I have been checking that post and he hasn't replied back yet.
DCosta9 Last edited by dcosta; 05-01-2017 at 11:01 AM. |
#5 | |
![]() Drives: 2019 ZL1-1LE A10 Join Date: Jan 2017
![]() Drives: 2016 Corvette Z06, 2018 ATS-V Join Date: Dec 2013
It would seem easy to check. Pull the filter and try again.
Perry
16 SharkGrey A8 Corvette Z06 18 Cadillac A8 ATS-V |
#7 |
I am getting the filter today. The problem is that it doesn't have the problem every single time. It is random. They seem the thing it has to do with humidity?
#8 |
If the filter is collapsing due to pressure drop, I would expect humidity would have little to do with it. I still suggest making a few runs (not in a sandstorm obviously) without any filter.
Perry
#9 | |
Bring It
Nope
#10 | |
Sometimes you just have to try things like this ..
DCosta9 |
#11 |
If the A10 does not do this and they use the same filter it my not be that.
#12 | |
We really need to combine these 2 threads on the same topic.
Perry
#13 |
Correct..I don't think it is the filter.
DCosta9 |
#14 |
Well, that's disappointing. I was hoping we had solved the issue. There are a few people on here who have had issues with fan belt rubbing on wires and causing similar issues. Do a search and see if you can find it. Good luck and let us know because I have the exact same issues!
