Old 04-30-2017, 11:44 PM   #1
nick_casper
nick_casper's Avatar
Drives: 16 2SS
Add another Whipple installed.
First press of the button and it fired right up. No codes so far. I reved it a few times on the second start and it sounds flippin sweet. I'll button it up over the next few days and give some impressions on how the canned tune performs.I submitted the start up vid so hopefully it worked.
https://www.facebook.com/nick.fuller...type=3&theater
2016 2SS, A8, Whipple 3.25 pulley, Mishimoto catch can, C7 Carbon fiber splitter and skirts, GM black brake and tail lights. PLX wideband O2/HP tuners. Apex VS-5RS in 19x11 and 19x12.
nick_casper is offline   Reply With Quote
Old 05-01-2017, 12:12 AM   #2
V8SS
Drives: 2017 M6 NFG
Congrats but the video link doesn't work
V8SS is offline   Reply With Quote
Old 05-01-2017, 06:50 AM   #3
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 05-01-2017, 07:02 AM   #4
cooden
cooden's Avatar
Drives: '16 Camaro 2SS & '15 Durango R/T
Nice! Should be picking mine up hopefully today or tomorrow at the latest. Rainy weather all week though, so I can't really "explore" this power.
'16 2SS: Summit White/Adrenaline Red/A8/Whipple Supercharger/ARH Longtube Headers/Corsa Xtreme Exhaust/Roto-Fab Cold Air Intake/Eibach Pro Kit/M228 Wheels/Lots of GM Accessories
cooden is offline   Reply With Quote
Old 05-01-2017, 08:12 AM   #5
Paully104
Novice Driver
Paully104's Avatar
Drives: 2016 2SS Silver
Originally Posted by nick_casper View Post
maybe this worked
Didn't work but grabbed the link for those who don't want to wait for you to fix, haha.
Modifications: BMR suspension & front brace, DSC v2 controller, ported throttle body, Rotofab intake, Rimblades rim protection (red)
Paully104 is offline   Reply With Quote
Old 05-01-2017, 10:26 PM   #6
nick_casper
Drives: 16 2SS
I spent the afternoon chasing error codes and running poorly at anything other than idle. The tech at Whipple was very helpful at helping me figure out the issue. The blue wire that goes from the four wire map ( hidden behind the supercharger ) had the pin pulled out of the connector ( may have been my fault). I rigged up a temporary connection that solved the issue until my new harness gets here. I just took my first drive with no issues. Next post is initial impressions.
Old 05-01-2017, 10:38 PM   #7
nick_casper
Drives: 16 2SS
I just took my first Whipple drive and here is my first impression of the canned tune. It is quiter than stock, I actually thought it stalled until I looked at the tach. The stock sound tube pumped a lot of engine noise in. The shifts seem firmer but it could be my imagination. The throttle response has been tweaked and actually has a bigger "deadband" than before. It drives close to stock and my wife will be able to drive it just fine. When I punched it from a roll it fishtailed and seemed to have way more body pitch, front up and whole car to the left before blowing tires into smoke - I let off before waiting on the nannies. It still backfires on shifts like stock and is very loud when the NPP opens up at WOT. You can hear the whine of the supercharger at idle and you cant miss it when revving. I only got to drive it for a few minutes since it's cold and late but what a rush. I'll post another impression after driving for a bit.
Old 05-02-2017, 05:45 AM   #8
brettman
Drives: 2016 Camaro SS
Cool, Oh I see now about blue wire, from other post.
Pull that NPP fuse (15 amp, #51)
brettman is offline   Reply With Quote
Old 05-02-2017, 06:12 AM   #9
DevBlackSS
DevBlackSS's Avatar
Drives: 2016 Camaro 2SS M6
Hail Yea Brother! Congratulations!
715whp/665tq
DevBlackSS is offline   Reply With Quote
Old 05-02-2017, 07:39 AM   #10
80sMetalDude
80sMetalDude's Avatar
Drives: .
Congrats! I cannot wait to start my build Friday night.
TY for sharing all the details.
80sMetalDude is offline   Reply With Quote
Old 05-02-2017, 10:20 AM   #11
nick_casper
Drives: 16 2SS
Message me if you have any questions during your install . Sit down and make a plan for mounting the coolant tank and heat exchanger. The instructions leave out a lot of detail there. I drilled through the crash bar and used 7" 5/16 bolts to mount the coolant tank. You may want to sleeve the plastic bores with tubing to prevent the tank crushing from the mounting bolts. The heat exchanger mounts in a way that is impossible to get to without trimming some plastics or a lot of major dissasembly. Another tip, have the adjustable pulley mounted to the bracket prior to install. It uses a sliding nut on the backside that is very hard to get to and falls into a bad spot when dropped
Old 05-02-2017, 10:58 AM   #12
80sMetalDude
Drives: .
Thx Nick between you and Brett I think we'll all be helping each other through this to a degree. Much appreciated.
Old 05-02-2017, 11:16 AM   #13
brettman
YES Sir, we (dumb asses) want a build to go smooth. foreseen problems addressed. Now a recommended fix not etched in concrete, if you have a BETTER way, PLEASE show us unworthy servants.....LMFAO....And lets build (and show) some HP..lol. Loving the car, forum and ppl, hats off.
Old 05-08-2017, 12:06 PM   #14
nick_casper
Drives: 16 2SS
A few pics.
So far I'm loving it.
