Old 04-28-2017, 04:54 PM   #1
My87z28
Drives: 1987 Z28, 385cid, '16 Camaro 1SS
ZL1 axles for an SS
Since we all know that the axles on this car seem to be on the weaker side. I'd like to know if the ZL1 axles are a direct fit for the SS. I realize that the ZL1 has the eLSD, but unless it's a completely different housing, I'd think they still fit. Does anyone know?
02/23/16: 1100, 03/16/16: 2500 # TGHR6N
03/16/16: 2500, 03/18/16: 3000 TPW : 4/11/16
04/8/16: built & VIN 04/11/16 - 04/28/26 : 4B00 Bayed QC hold, 04/29/16 : 4200 Rail yard
'16 1SS 6M, black with jet black interior, split spoke gray machined faced wheels, and black front/rear bowtie emblems.
My87z28 is offline   Reply With Quote
Old 04-28-2017, 05:32 PM   #2
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
I believe at least one is a different length but I do not have a definitive answer on this. They do sell aftermarket high HP axles though.
Eric SS is offline   Reply With Quote
Old 04-28-2017, 06:27 PM   #3
My87z28
Yeah, I know about the Gforce axles, but I consider $1700 for set of axles to be asinine. Especially considering the Strange pro race axles in my drag car were less than $500, and are built to handle twice the power. If Gforce is the only option for a stronger axle in these cars, then someone needs to developed a more budget friendly axle for these cars. Otherwise I foresee quite a few budget bolt on guys with laid up cars.
Old 04-28-2017, 06:30 PM   #4
Eric SS
#becauseracecar
Eric SS's Avatar
I definitely agree with you there.
Old 04-28-2017, 06:51 PM   #5
crash0117
Drives: 2016 1SS Camaro
Driveshaft Shop makes them as well. That's where I got mine from. They are $1500 a set.
crash0117 is offline   Reply With Quote
Old 04-28-2017, 07:03 PM   #6
My87z28
Yeah, just read about theirs.$1500 is a tiny bit better, but I think it would be ideal for someone to make a set in the $700-900 range. Sure they wouldn't be as strong but I'd bet they'd sell twice as many as Gforce and DSS.
Old 04-30-2017, 04:07 AM   #7
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
I agree with this for 90% of mods right now. The prices just seem too high, but I guess it's the price we pay for modding new cars
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 06-07-2017, 08:12 AM   #8
Fraxum
Fraxum's Avatar
I wonder isn't it cheaper on a lower HP (<600rw) car not on slicks just to replace the stock axles rather than buy stronger axles and break the much more expensive diff? Sort of like the shear pin on and outboard motor.
Old 06-07-2017, 09:24 AM   #9
Perdieu
Perdieu's Avatar
Drives: 2017 Nightfall Grey Auto 2SS
LMAO at the 700-900 range. The parts and material to build them cost more then that.
Also your 700-900 half-shafts wouldn't come with the life time warranty
Perdieu is offline   Reply With Quote
Old 06-07-2017, 10:07 AM   #10
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
ZL1 (coupe) and SS 1LE with the eLSD have a shorter right side axle do to the eLSD's different shaped housing. So you can't directly swap axles in a regular SS.
Old 02-23-2019, 01:10 PM   #11
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Anyone figure this out? I have a chance to buy a zl1 1le M6 diff, axles, and driveshaft for a m6 SS. Easy swap? Or will it fit?
