Old 04-25-2017, 09:16 PM   #1
MAGAUSA
MAGAUSA's Avatar
Drives: 2017 Hyper Blue 1LE
Cutting through it all, which catch can?
I know, I know. I've used search. However, which ones are easy to empty/service, capture these unicorn or not engine oil blow by particles?
Something clean, simple, easy to service.
I'm going to open my intake before I do this, but help me plan - which one is good for a NA engine, no intention for FI or internal motor build. Just want to "potentially" avoid carbon build up. Gracias.
MAGAUSA is offline   Reply With Quote
Old 04-25-2017, 09:24 PM   #2
devnull
Scientific negotiator
devnull's Avatar
Drives: 2019 Grand Sport
http://www.eliteengineeringusa.com/e2-catch-can/
I've used these forever on many LS motors and a couple of LT1's now. They work GREAT
Also...
https://www.mishimoto.com/chevrolet-...-can-2016.html
Many use this one with similar success. The kit and tubing is designed for this car. Both work, and so either would do (preferences aside)
2019 Grand Sport M7
2018 ZL1 1LE 6MT
2017 SS 1LE 6MT
Matthew 25:40
ΜΟΛΩΝ ΛΑβΕ
devnull is offline   Reply With Quote
Old 04-25-2017, 10:50 PM   #3
Hard Parker
Hard Parker's Avatar
Drives: ZL1
I have heard Elite Engineering and Mighty Mouse are the top two
2017 Camaro 1LE Nightfall Gray Metallic RIP ☠️☠️☠️
2017 Camaro ZL1 Black Exposed CF|Sunroof|6 Speed
Click HERE to follow my build!!
Click HERE to follow me on Instagram
#savethemanuals
Hard Parker is offline   Reply With Quote
Old 04-25-2017, 11:23 PM   #4
slick3
Drives: Garnet Red - 20 ZLE
I was turned off by elite engineerings mounting position when they first came out for these cars not to mention double the price. Not sure if it's any different now. With that said, I went with the mishimoto. I pulled the intake off my car last month and there were very small traces of oil in it from what I could see and feel, I would consider it a film if anything. I have no idea how much more effective,if any , the elite or other catch cans are. But that's my expierence with the mishimoto at the 4500 mile mark. It was on the car with 300 miles on it
slick3 is offline   Reply With Quote
Old 04-26-2017, 10:35 AM   #5
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
I have used the Mishimoto catch can and because it is made for our cars would definetly suggest that one. So much easier with good quality hoses and connections. Makes elite catch cans from easy to 15 minute stupid easy. I just changed my oil over the weekend and got a 1/4 cup of oil. So not much but at 7500 miles that is almost 4 cups of oil or a quart poured down the intake. I have to assume as time goes on that will increase with ring wear. Just my thoughts on the subject.
Second thought: I am going to add this so I never have to unscrew the can anyways. Just stick a bottle under the pecock and drain when ever. Although you can easily just do it when you change the oil.
MISHIMOTO BAFFLED OIL CATCH CAN PETCOCK DRAIN KIT
MODEL: MMBCC-DRAIN-01
drivingagain is offline   Reply With Quote
Old 04-26-2017, 11:18 AM   #6
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Only if Elite can design a "formed fitting" hose routing that can accommodate our supercharged engines .(PD) I'd be all over it.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 04-26-2017, 02:52 PM   #7
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
I have the elite engineering one and I like it. Mine mounts in the same spot as the mishimoto
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 04-26-2017, 03:36 PM   #8
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
Our Elite E2 and E2-X Catch Cans are the most effective on the market, period. Take ANY other brand mentioned and install the E2-X in series AFTER the other can starting with both oil free. Drive 1000 miles and drain both documenting what was caught. The E2-X will trap us much or more AFTER the vapors have already passed through the other can. Now clean both and reverse the order and after 1000 miles almost nothing gets past the E2-X. That simple. 1/4 turn ball valve for easy draining and the billet cleanside separator to complete the system.
It is a no brainer when looking at your GDI engine that cannot tolerate any oil and other contaminate ingestion.
Elite Engineering is offline   Reply With Quote
Old 04-26-2017, 06:15 PM   #9
MAGAUSA
MAGAUSA's Avatar
Where does the E2-X mount in our cars?
Old 04-26-2017, 06:30 PM   #10
Hyper1SS
Hyper1SS's Avatar
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP
I 2nd that!! Did not like the mounting on the Elite catch can. Looks like a universal mount unlike the Mishimoto setup that was made for our cars. Like the formed hoses and quick disconnects like factory. Go with Mishimoto
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates.
Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges
Order ID: TDHQMS
1100 on 01/07/2016 at Penske Chevrolet
6000 on 02/23/2016 Delivered to customer
Hyper1SS is offline   Reply With Quote
Old 04-26-2017, 06:36 PM   #11
MAGAUSA
MAGAUSA's Avatar
Are you able to unscrew the can to empty or do you have to take the whole unit down, unscrewing the mounting bolt?
Old 04-26-2017, 06:55 PM   #12
devnull
devnull's Avatar
I can unscrew it without unmounting, and that's also with a strut tower brace. It's clean...
2019 Grand Sport M7
2018 ZL1 1LE 6MT
2017 SS 1LE 6MT
Matthew 25:40
ΜΟΛΩΝ ΛΑβΕ
Old 04-26-2017, 07:09 PM   #13
MAGAUSA
MAGAUSA's Avatar
So you have to push the hard plastic L shaped hose out of the way to make it fit there?
Old 04-26-2017, 07:11 PM   #14
devnull
devnull's Avatar
Nah, that's kind of a strange angled picture. That hose is empty (it is the "sound tube" that runs intake sound to the cabin). Many just remove it, and frankly I will too.
It does not crush from this though.
Edit: My own pictures just cost me $2k in intake and headers.... HAHA I NEEDED THAT!
2019 Grand Sport M7
2018 ZL1 1LE 6MT
2017 SS 1LE 6MT
Matthew 25:40
ΜΟΛΩΝ ΛΑβΕ
