Old 04-25-2017, 08:47 PM   #1
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
Line lock mock up/install
So, I got tired of waiting on a company to come out with an easy kit to do a line lock for our cars. Unfortunately the only solution that I've found is one very similar to the newer mustangs. Our cars have a European style ABS system. Meaning each line out of the master to the ABS block controls a front and rear wheel. You can no longer just put a solenoid between the master and the ABS block and go. We now require two solenoids, one for each front wheel. That jumps the cost significantly. I'm going the "easy" way out. I have seen photos of both solenoids right after the ABS block, but it's a bit cramped for my liking. I'm going right at the junction of the hard line and the rubber hose. This will allow me to upgrade to braided lines when I get the extra funds. So far I'm into this venture for about $200 just in a pair of B&M solenoids and the fittings to adapt it.
Stock junction
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 04-25-2017, 08:48 PM   #2
Cdflyer
Cdflyer's Avatar
Planned location of the solenoid.
Old 04-25-2017, 08:52 PM   #3
Gilley
Gilley's Avatar
Drives: 16 Red Hot 2SS
Interesting.subscribed for updates.
'16 Red Hot 2SS A8 sunroof
Gilley is offline   Reply With Quote
Old 04-26-2017, 07:26 PM   #4
Cdflyer
Cdflyer's Avatar
Minor set back today. The fittings I ordered are not right....that's what I get for guessing. Worst part is it seems the ends are a weird size. So after about 2 hours of running back and forth between parts stores, I'm no closer to fitting these.
Old 04-27-2017, 07:31 PM   #5
Cdflyer
Cdflyer's Avatar
Finally got it situated in a position I like. Plenty of room, once I got out of my own way. It'll even hide behind the inner wheel well. Now to button everything up, and duplicate it for the driver side.
Old 04-28-2017, 07:15 PM   #6
Cdflyer
Cdflyer's Avatar
The only evidence that there is a line lock hiding under there.....
Old 04-29-2017, 12:33 PM   #7
Perdieu
Perdieu's Avatar
Drives: 2017 Nightfall Grey Auto 2SS
very nice, might have to copy it.
Perdieu is offline   Reply With Quote
Old 04-29-2017, 10:08 PM   #8
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
Good stuff. I knew the 5th gen had kits for it. Good to see a diy for the 6th.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 04-29-2017, 10:33 PM   #9
SGDM
SGDM's Avatar
Drives: 2016 2SS
That is pretty slick, thanks!
Who Dares...Wins
SGDM is offline   Reply With Quote
Old 07-26-2017, 07:08 PM   #10
B&MRacing
B&MRacing's Avatar
Drives: 2016 Camaro SS
Very tricky installation! Nice work.
B&MRacing is offline   Reply With Quote
Old 07-27-2017, 08:14 AM   #11
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Glad I saw this, sub'd as well
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 07-27-2017, 08:28 AM   #12
DFW1LE
DFW1LE's Avatar
Has anyone looked at how the ZL1s LL is configured and if it can retrofitted to an SS?
Old 07-27-2017, 09:36 AM   #13
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Is it even available to purchase independently? I think some of the model specific parts are limited supply for a while, like the short throw.
Old 07-27-2017, 10:15 AM   #14
JKLNHYD
Defending the Nation...
JKLNHYD's Avatar
Drives: '16 Summit White 2SS, A8, Sunroof
I believe trying to retrofit LL from the ZL1 would be difficult considering there are electronics involved. It appears with this setup, it avoids all that.
'16 2SS, A8, Sunroof, non-NPP
"SURSUM AB ORDINE"
JKLNHYD is offline   Reply With Quote
