Old 04-21-2017, 03:53 PM   #1
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Sport vs. Track mode
Hi guys,
Still trying to learn how this fabulous car works. Regarding the drive modes, I find the throttle more responsive in sport mode, at least in the first third of pedal travel. But when you get more into the throttle in track mode, the car really goes. Does this sound about right? Is the throttle less responsive in track mode at lower pedal positions for better control on the track?
Thanks.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 04-21-2017, 04:00 PM   #2
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
I thought I liked Track mode's throttle response until I actually got on-track, where I found it lacks upper-torque resolution and ends up behaving like an on/off switch at higher loads. No bueno. Now I prefer Sport mode's throttle response.
Down the road, I'll map my torque request mapping via HP Tuners to make Track mode more linear in its response, but for now I'm putting up with the stock mapping to appease the Warranty Gods.
The car makes the same torque in the different modes, but the pedal mapping changes, thus giving a different feel and perception.
Old 04-21-2017, 04:05 PM   #3
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Thanks. I guess that's what I'm feeling. Motor "feels" a little soft until you get into the throttle, then bang. I'm street only and not sure which mode I like better, although I like the suspension feel of track mode better.
Looks like we both have similar genetics. Same color car, good taste in motorcycles.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 04-21-2017, 04:12 PM   #4
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Yup, you have the hang of it. The track mode gives a bang, which ironically is not what you want on the track. Unless it's so they can better implement the PTM, in which case I can understand it from that chassis dynamics tuning perspective.
Very nice bike you have there! Great minds think alike.
Old 04-21-2017, 04:17 PM   #5
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Has anyone released a map of what the three modes look like on a graph? I'd be curious to know the actual throttle % for a given pedal %
Eric SS is offline   Reply With Quote
Old 04-21-2017, 08:27 PM   #6
glenB
Drives: Chevrolet Camaro SS
During one of tests sessions for MT, Randy Probst said that he asked the GM engineers to reduce throttle tip-in in Track mode to help the loose out/throttle application. He said GM listened. So if the throttle is a little lazy you can thank him. I prefer Sport mode.
glenB is offline   Reply With Quote
Old 04-22-2017, 03:30 PM   #7
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
And what about the dual mode exhaust, sport vs. track? Sounds the same to me.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 04-22-2017, 03:41 PM   #8
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Thanks. It's an unbelievable machine, and I've owned many, many liter+ bikes. Full exhaust and a flash = 212 rwhp, AND you can tour on it!
Sorry to go off topic.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 04-22-2017, 03:42 PM   #9
glenB
Track is open all the time I believe. To me, it sounds like at steady state in Sport it tones down, like the valve closes a bit.
Old 04-22-2017, 08:27 PM   #10
TJay74
So I'm not crazy, well anymore than what my wife already says I am. I have driven in Sport now since I bought the car. I tried Track mode the other day for a day and noticed almost immediately that the throttle tip in was way off compared to Track mode.
Old 04-27-2017, 10:00 AM   #11
SaphfireSS
Drives: 2017 Camaro 1LE SS
Just wish we could have track mode suspension settings with sport throttle. Without a tune. Lol
SaphfireSS is offline   Reply With Quote
Old 04-27-2017, 02:38 PM   #12
M.A.K.
Drives: 2017 SS 1LE , 75 Caddy, 15 Cruze
Just set your suspension and steering in the menus too however u like, throttle response should still change with the mode selector.
M.A.K. is offline   Reply With Quote
Old 04-27-2017, 02:43 PM   #13
00 Trans Ram
00 Trans Ram's Avatar
Drives: 2017 2SS
Actually, you can.
With a throttle controller, it'll give you more tip-in at lower throttles. But, that means that you naturally have less at higher throttles.
Check out this http://www.camaro6.com/forums/showthread.php?t=488478
00 Trans Ram is offline   Reply With Quote
Old 04-27-2017, 02:56 PM   #14
Sleeks
Drives: None
You can set steering, exhaust, and suspension separate using the mylink settings. Then use the mode switch to go to sport and throttle will be sport.
For instance, you could set:
suspension - track
exhaust - track
steering - tour
mode switch - sport (throttle where you want it)
-Brian
Hyper Blue 1SS / 1LE
Sleeks is offline   Reply With Quote
