Old 04-21-2017, 09:55 AM   #1
OddJack
OddJack's Avatar
Drives: Submarine
Do you apply Parking Brake every time you Park
Cuz if you dont, you should. Every single time. Regardless if it's uphill, downhill or flat. This is not only safer, it's better for your transmission.
And there is correct way to apply the parking brake, also known as emergency brake:
You come to a stop with your foot still on brake pedal, and while you are still holding pressure on the brake, you push, or pull, the parking brake, depending on the type of car you drive.
After that, if its an auto, you shift to P. If it's a manual put it in first gear. The important part is that the car is hold first by your brakes, not your transmission.
I know many of you do this already, but after seeing the reactions to the other thread I doubt everyone does it, or does it correctly.
OddJack is offline   Reply With Quote
Old 04-21-2017, 10:02 AM   #2
USBI
Drives: 2017 1SS 1LE
Delete
USBI is offline   Reply With Quote
Old 04-21-2017, 10:07 AM   #3
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
Never ever use my parking brake. Never will.
About 28 years ago I used it on my truck in the winter time. It froze. Took me 4 hours laying under to get it thawed out.
I swore I'd never use one again and never have.
Rainbow1616 is offline   Reply With Quote
Old 04-21-2017, 10:11 AM   #4
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
I always do. No matter if it is in the garage or anywhere. Just part of the shut down process for us.
BrianL is offline   Reply With Quote
Old 04-21-2017, 11:07 AM   #5
Alanarchy
Alanarchy's Avatar
Drives: 2017 Camaro SS NGM, 2025 F150 XLT
Always.
Alanarchy is offline   Reply With Quote
Old 04-21-2017, 11:09 AM   #6
F1FTY
Drives: 2018 ZL1
Pretty much never unless i'm on a large incline. Learned it from the track where you do not apply the parking brake after a session. The stress on a transmission is next to nothing if you are parked flat. Also, if you are on an incline pointing downwards, I would put the car in reverse, not first gear even with the parking brake on.
F1FTY is offline   Reply With Quote
Old 04-21-2017, 11:18 AM   #7
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Apparently not everyone has learned their lesson from the other thread. The OP's first post is not to be disagreed with. It is 100% correct and accurate.
What is wrong with you guys?...
Old 04-21-2017, 11:20 AM   #8
Max Headroom
Drives: 2018 GMC Canyon, 2016 Camaro 2SS
Always have, always will.
Max Headroom is offline   Reply With Quote
Old 04-21-2017, 11:36 AM   #9
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
LOL.....
Old 04-21-2017, 11:51 AM   #10
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
Agreed.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 04-21-2017, 11:52 AM   #11
F1FTY
Drives: 2018 ZL1
Nothing is wrong with me or my car. I've driven manual for over twenty years and have never had an issue. I practice common sense and have hundreds of thousands of miles under my belt with a lot of combined track and autocross time that mitigates the usage of a parking brake. Google is a great resource for seeing the effects of using a parking brake after a hard drive or when the rotors have heat in them. To put it simply, i'm not going to change habits that have worked for me based on a forum post and someone else's experience through their own filter.
If the car is on an incline, I will use the parking brake. If the car is parked flat, I will not.
Old 04-21-2017, 11:55 AM   #12
cleverCamaroName
Drives: N/A
this dude's posts sound like buzzfeed ads
cleverCamaroName is offline   Reply With Quote
Old 04-21-2017, 12:02 PM   #13
OddJack
OddJack's Avatar
Drives: Submarine
There are dudes who are here for sharing info, and there are dudes here who are here cuz they need attention, or a challenge, or some sort of distraction from their misery.
The latter, thus, focus on the characters, not what being said or discussed. Because they have no interest in it.
Whatever you are here for, I will never insult anyone, unless I am insulted first.
So you decide which way you want to go.
Old 04-21-2017, 12:05 PM   #14
fastball
Drives: 2017 Camaro 2SS 6MT
It froze because you probably didn't use it on a constant basis before hand, then decided you wanted to use it and the cable was frozen and/or rusted stiff.
Use it all the time from the day you buy the car brand new it will never fail. Since I started driving in 1993 I've racked up over 400,000 miles of driving over 4 cars. Always used the parking brake on all of them, automatics and manuals, every time I parked no matter the terrain, it's never failed.
fastball is offline   Reply With Quote
