HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
Drivers seat automatically moved back while driving?
So i was driving diwn the road while in 5th gear and all of the sudden, my drivers side seat starts to move im the all the way back position. Wtf? So i pressed the 1 key on the door and held it back down ( memory) to move it back up while still driving. What gives?
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
![]() Drives: 2ss Nightfall Grey Join Date: Dec 2016
I've not had that happen, but I did turn the option off to prevent automatic movement of my seat in the menu. Truthfully that could be dangerous in a manual car epecially if you're not tall enough to continue reaching the pedals and see what's in front of you after the seats slide to the back.
![]() ![]() ![]() ![]() ![]() Drives: '17 ZL1 Join Date: Jul 2016
Here are a few ideas:
- Maybe the switch on the seat is faulty? - Do you have the easy exit option set where it moves the seat back when the driver door opens? If so, maybe the door sensor for a brief moment thought the door was open. - Any chance the "2" was bumped and is programmed for the seat to be all the way in the back position? |
HYPER SS
I don't think any of that applied.. I did look at all scenarios more closely after I parked. only thing I can think is that A) could be a faulty switch. B) the car was ticked at me for some reason?
Ordered: 1/15/2016
![]() Drives: 2017 2SS, Twin Blown 429 LSX Av Join Date: Sep 2012
My less than 2 week old 2SS just did the same thing and memory buttons became non-responsive. Shut down and restarted... had to use the switches on the seat to get it back where I wanted it. Started driving and it gave a couple of rearward blips, then 30 sec later it decided to move all the way back again. Shut down for 30 min, restarted and memory switches were working again. 2 miles down the road seat slides back all the way again. Seems to be a controller or comms issue.
2017 Black 2SS, A8, Mag Ride, Recaros....
#6 | |
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
They can't be trusted.
