Old 04-18-2017, 09:58 AM   #1
TDS
TDS's Avatar
Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10
Paint Protection Film Install, Installer said the seam was unavoidable UPDATE
Good Morning everyone.
This is a question for those that have film installed on there front bumper. The installer says the seams were unavoidable do to the angles on the bumper, Actually the owner of the shop said that. When I dropped the car off seeing the edges of the film was my main concern, so this is driving me crazy. If it the way it has to be I will live with it or just have it removed if it get one my nerves worse then it already is. I am not trying to be that guying even though that what I am being, but it was a lot of money. Please shoe pictures of your install if you have them or tell me it is normal. Would love to here a from an installer. My buddy dropped off his car at the same shop yesterday and if its wrong I want to let him know ASAP then I will deal with mine later.
Name:  Right Front.jpg
Name:  right front seam.jpg
Name:  left front.jpg
Name:  left front seam.jpg
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats
Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer
TDS is offline   Reply With Quote
Old 04-18-2017, 10:46 AM   #2
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
Does not look normal. My GT350 came with it from the dealer and looked perfect. It does make the white color Off-White compared to the rest of the car.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 04-18-2017, 10:50 AM   #3
Infern0
Bring It
Infern0's Avatar
Drives: In Between
That is "normal" for a shop that is using templates for their pieces. The Xpel shop I used for example uses templates. The number of exposed radial angles makes it difficult to do without the relief lines included in the template pieces, which creates those seams. If you had a place that didn't use templates, but used a bulk wrap, they may be able to get more creative with their application and where they put the seams. There can be other drawbacks from that though because the seams are also designed to prevent the installer from having the stretch the material too much, which can create a haze or fog; which when clarity is the goal, you do not want.
My install had a couple of imperfections including one of the seams so it's over there getting corrected right now. I'll post pics when I get it back today or tomorrow.
What I can tell you from your pics based on my install is that it looks pretty standard. Maybe a fingernail gap bigger than mine was, but that'll allow you to keep it cleaner. Dirt in your edges makes for a bad looking black line.
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 04-18-2017, 10:52 AM   #4
hawk02
Coupe Newbie
hawk02's Avatar
Your installer is correct that a seam is unavoidable on the front bumper. The question really becomes where to put the seam.
My installer ran the seam along the ridge on the top of bumper in a more front to back direction. It's visible if the light hits it in the right direction, or you really look for it. At a casual glance, you don't know it's even there.
It really boils down to how noticeable the seam is when you look at the front of the car. Like I said, mines isn't easily seen unless you really look for it. The black color probably helps to hide the seam as well.
Old 04-18-2017, 11:00 AM   #5
TDS
TDS's Avatar
I did not think it looked normal ether, On the bright side the film did not hardly change the color at all.
What you are saying about stretching it makes since. The left seam on mine was done much better then the right. I will be curios what yours looks like the second time around now that they know the car better.
Travis
Old 04-18-2017, 11:00 AM   #6
IneedAZ
IneedAZ's Avatar
i have to look when i get home at my seems, can't remember where they are. I know i don't see them unless up close looking for it.
Old 04-18-2017, 11:04 AM   #7
Infern0
Bring It
Infern0's Avatar
Drives: In Between
There should be no discoloration though. I have white and depending on the angles some portions look like a flatter white until you look back from a different angle. I'd hope that's what's happening in your pic.
Old 04-18-2017, 11:07 AM   #8
TDS
TDS's Avatar
I am glad to here that the seam needs to be there, makes me feel better. Hopping when the sun shines on it that the seam does not stand out to bad. I bet your right and the black helps.
Travis
Old 04-18-2017, 11:08 AM   #9
cleoent
cleoent's Avatar
Drives: 16' Camaro E-Force SS
There is a two piece install and a three piece install. I wasn't happy about it either. My front bumper is the three piece install so I actually have four different seems in front bumper. After my initial disappointment I haven't thought about it since.
Leo
2016 e-Force 2SS
Instagram @cleoent
cleoent is offline   Reply With Quote
Old 04-18-2017, 11:13 AM   #10
TDS
TDS's Avatar
[QUOTE=Infern0;9679442]There should be no discoloration though. I have white and depending on the angles some portions look like a flatter white until you look back from a different angle. I'd hope that's what's happening in your pic.
I took those pictures this morning in the garage with the flash on my cell phone, I think amplified the edges, color looks good in person
Travis
Old 04-18-2017, 11:14 AM   #11
hawk02
Coupe Newbie
hawk02's Avatar
That makes sense. I'm guessing mine was a two piece install since the only seams I have are along the top ridge of the bumper.
Old 04-18-2017, 11:20 AM   #12
TDS
TDS's Avatar
Will I am glad I don't have the 3 piece install I hoping to let it go too. Now that I know it is common that will help.
Travis
Old 04-18-2017, 11:26 AM   #13
trident
No Hope
trident's Avatar
Drives: 2017 ZL1 Black Coupe, 2017 Z06,
Looks OK
As long as there are no bubbles, debris in the wrap the seams look great and I would have no problem with them. Both your white car and the black car look great, but do not tolerate bubbles and marks in the wrap. Looks good. Do you mind sharing the price?
trident is offline   Reply With Quote
Old 04-18-2017, 12:03 PM   #14
TDS
TDS's Avatar
There is a couple really small bubbles but they say they will go away.
I think the price was very good.
$3500.00 for the following; film on full front bumper, full front splitter, full front fenders, full hood, full side skirts (or what ever you call them) little spot in front of rear tire, lower part be hide rear tire. Paint correction to get some hard water spots off the car, then full clay bar treatment. Ceramic coating over the whole car, Pulling the wheels off and ceramic coating them. Tinting all the windows but the windshield and tinting the 4 side markers and the third break light. Also they coated the out side of the widows with something.
Travis
