![]() Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
ProCharger F1A with a A2W intercooler set up (w/ pics)
Quick Pictures of the F1A and Air to Water Intercooler set up, with the ProCharger Sheet Metal Intake..
Baseline numbers were 424/406 with a Roto-Fab and SW Cat back Last edited by Perdieu; 04-17-2017 at 05:37 PM. |
![]() Drives: 2016 Black 1SS Camaro Join Date: Jul 2012
Beautiful set-up!!
Any numbers on it yet?
2016 Camaro 1SS M6 with MRC and NPP.
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” Albert Einstein |
#4 | |
![]() ![]() ![]() Drives: 2018 ZL1 Join Date: Oct 2011
2018 ZL1…Many mods to come
#5 | |
![]() Congratulations!!!!
SABIO
550HP for Sure!!
#7 |
![]() Drives: 2016 2SS Camaro Join Date: Apr 2014
Can't wait to see what kind of numbers you make. Eventually I'll be going to at least upgraded pistons if not rods and maybe stroker like your build. Currently making 13.5 lbs on my f-1a on stock internals with meth makes 720 rwhp
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
Beautiful. I just wish there was some way to get the darn filter off of the top of the headers.
#9 | ||
I'm going to see what else we can come up with for it, working wit ha company on a new hood that will let me have a different place to pull the air from
#10 |
So as long as the air is cooled prior to entering the motor it will have the same values as if it were cool coming from the filter? It just seems to me that you can't create atmosphere that wasn't there to begin with without chemicals. I don't do much FI and the ones I do are not set up that way, so those are serious questions.
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
I am sure sucking hot air is not the perfect set up but it works and works well. I have seen people make a cold air filter pipe for their procharger and actually lost power. The added restriction hurt more than the cool air helped.
My turbos suck hot air too. My thoughts are it would be better to build some kind of scoops or airdams that push cooler air toward the filters but that could create other issues. Perdieu, that is a really clean set up. I am anxious to hear some numbers. Are you working on your fuel system?
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
#12 | |
With a Air to Water you can achieve the same results as above. However in daily driving it can sometime be worse if the IC water becomes heat soaked. THE BIG KEY is when you add in ice water (right before a pass) you can and will see temps BELOW ambient for most of if not all of the pass. I've seen drops close to 30* bellow ambient in 100* temps. With that said my set up is not for most people. I'm chasing a number and wanted all the advantages I could get. ProCharger knows this and offered me the beta setup to do some real world testing. |
#13 | |
I'm not even going to tune it until the swap (starts next week).. drove it 100 miles yesterday on the stock tune,, sucked not going WOT but I don't want to waste time tuning only to have to start all over after the swap |
#14 | |
I know that with my car in its current form by the time I launch the car my IAT's are at least 20* above ambient if not more. It isn't real but the ECM thinks it is and wants to adjust accordingly. I know I am preaching to the choir but I am trying to get others opinions since I will eventually be going FI.
