Old 04-17-2017, 04:18 PM   #1
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Smallest spacers to get 2 degrees front camber with 19x10 ET25?
Tried to get my car track aligned today and they most they could do is 1.2 degrees (front) without the wheel hitting the strut reinforcement (MRC). Wheels are Apex PS-7 19x10 ET25. Do you think I could get away with a 3mm spacer to get me to 2 degrees or should I go with 5mm? I want to use as small of a spacer as possible. Thanks.
Eric SS is offline   Reply With Quote
Old 04-17-2017, 11:51 PM   #2
JaxChris
10mm. You're running 1.5" more wheel width than stock and you also tucked an extra 2-3mm inboard with the 25 offset.
I figure your max safe camber in the front would be about ~1.5* currently if you are running 30 profile tires, ~1.4* if you're running 35 profile. A 10mm spacer is about 0.38 inches, which would give you about .43* of additional negative camber, getting you very close to ~2*. If you want to hit 2* and be safe, try 14mm. If you want to push the limits, try 12mm.
I would get appropriate wheels that suit your intended goals.
Good luck.
Old 04-17-2017, 11:53 PM   #3
Eric SS
#becauseracecar
Eric SS's Avatar
Good luck.
Thanks for the info. It's the wheel that is close, not the tire so the aspect ratio won't make a difference. And10mm is to wide for me to be comfortable on a race track. Maybe I'll go with 5mm and shave a little off of the strut.
Old 04-18-2017, 12:06 AM   #4
JeromeS13
Drives: 2017 1SS/1LE
With my camber maxed out (haven't had it on the alignment rack to check actual camber since doing that, but measured with a level @ -2.2 degrees), I have ~ 6mm of clearance to the strut on my 20x10 +20 1LE wheel. So, you could probably get away with a 5mm spacer and be good. However, you'll probably be REALLY close to getting 7.5 turns worth of lug nut engagement on the studs. The most I would run on OEM studs would be a 3mm spacer, which might be too close for comfort.
Old 04-18-2017, 07:06 PM   #5
citizennick
Drives: 2016 2SS
MRC car here. I'm at -2.5 up front on a 285/30/20 20x9.5 et19. Basically the same poke but your inset is 13mm closer to the strut than me. You might be able to get away with a 10mm spacer.
Edit: of course my photo gets uploaded sideways.
2016 2SS M6 Black/Adrenaline Red
589rwhp 572rwtq 429 LT1
citizennick is offline   Reply With Quote
